Hello Oldschool!
I'm new here and thought I'd ask around here about my current issue. Not sure if this is the right forum if so mods feel free to move to the right forum.
So I've gotten into the world cars about a year ago and it's amazing!
So I brought a 1985 Mazda 323/Familia with a E5 engine off a mate for $500 that had a dying engine. It was overheating dramatically and he didn't top the coolant/oil up in a long time. Finally it soon wouldn't even start. So a had a few mates have a look at it with me and I took off the rocker cover and coolant was sitting there with the oil, not a good sign at all. Took the head off and guess what? 3 pistons had coolant sitting ontop of them. We knew by now the engine was history.
I found a E3 engine (The engine spec lower than the E5, 1.3l 8valve sohc) for $180 and went ahead and brought it. Ive read that you can run drop it straight in and mostly everything will be fine. So we dropped that into the bay and brought new clutch at the same time. After getting everything bolted in and secured we topped up the coolant/oil/tranny oil and I went to turn the key. NOTHING!
So the car has been sitting in the drive since. I had the battery fully charged with a bench charger overnight and it was purchased in January 2012, I cleaned the battery connectors and tried, this nothing. Now Im looking at the starter motor wiring, checked that out and that's fine, decided to take the starter motor out and bench test and yes it engages and does spin freely.
We thought about giving it a roll start and therefore did that down a hill, that didn't do the trick because the car wasn't getting any spark either. tested the spark plugs and no spark and checked the ignition coil wiring and that's fine and took the dizzy cap off and checked that out and it's clean.
So I've got two problems now, nothing when I turn the key and no spark? I am getting a click from a relay however. Where should I go from here before getting a mechanic to check it out?
Anymore I have to provide?
Here are some progress pictures I took.
Many thanks!
