Guest LS 2 THE DEEE Posted April 14, 2013 Share Posted April 14, 2013 Hi all Do the turbo oil lines on the 1jzgte run into the sump or the block? I only ask as Im looking for a front sump and have been offered a ge front sump to run on my gte ( motor is in storage otherwise I would look myself) And if it is the case could I run the ge sump and mod it to accept the oil lines...in other words would that be difficult? Cheers Levi Quote Link to comment Share on other sites More sharing options...
Guest Coldspark Posted April 14, 2013 Share Posted April 14, 2013 http://www.driftworks.com/forum/engine-drivetrain/179437-1jz-n-front-sump-twin-turbo-oil-feed.html Quote Link to comment Share on other sites More sharing options...
Guest HighLUX Posted April 14, 2013 Share Posted April 14, 2013 The non turbo engines have the casting for the oil return, just needs to be drilled and tapped 1 Quote Link to comment Share on other sites More sharing options...
Guest LS 2 THE DEEE Posted April 15, 2013 Share Posted April 15, 2013 The non turbo engines have the casting for the oil return, just needs to be drilled and tapped Cool sounds like a go for ge sump then one other thing is that the sump has been notched to fit in a nissan apparently should I be worried at all about that? Quote Link to comment Share on other sites More sharing options...
Guest Seedy Al Posted April 16, 2013 Share Posted April 16, 2013 only if its been done shit but i wouldnt worry about it to much Quote Link to comment Share on other sites More sharing options...
