Guest Liam Wedlake Posted March 31, 2013 Share Posted March 31, 2013 Hello all. I have a 1982 Holden Gemini, it is getting a CA18DET and 5 speed conversion sometime this year. I was just wondering about electronic speedometers. Some of my questions include, can you get a certification with a electronic speedometer? Will I be able to get one to work off of a CA 5-speed gearbox (I've never dealt with any Japanese cars so I have no idea. If they have a electronic speedo or not?) Thanks to any body who has the slightest information on this subject. Quote Link to comment Share on other sites More sharing options...
Guest nigelwade Posted March 31, 2013 Share Posted March 31, 2013 cert would be no problem at all; either as a retro fit in the dash, or a floating mount, I think either would be fine. But it would have to be accurate within +/- 5kph , as for whether the engine has one or not couldn't say. Quote Link to comment Share on other sites More sharing options...
Guest flyingbrick Posted March 31, 2013 Share Posted March 31, 2013 If you can't get an electronic sender that's a straight fit into that box... Then there are many other options to make it work. Aftermarket speedos eg autometer are adjustable to suit any diff/ tire size etc Quote Link to comment Share on other sites More sharing options...
Guest HighLUX Posted March 31, 2013 Share Posted March 31, 2013 Being nissan lego spec its possible an electronic speedo sensor from a 25det gearbox or similar will work 1 Quote Link to comment Share on other sites More sharing options...
Guest johnny blz Posted April 2, 2013 Share Posted April 2, 2013 hey man i recently did a ca into my ke70. im using a rb20 mechanical speedo to factory cluster. its pretty close, about 8km/hr faster. But ive got 13'' rims on. Also a rb box is 75mm shorter then a ca/sr box if your fighting space. Hope it helps. Quote Link to comment Share on other sites More sharing options...
