Mazda 626 drift missile
dohcturbo626
Hea a few pics of mi car nd the project which started three years ago in jan 2010
It was first built as a road car but gave up on the idea after a few 2 many fines nd a slight prang in the rear end.
Now I plan to drift it nd have only the cage left to build but I'm sure it will be under constant development for life.
Specs
Mazda 1979 626 rwd
2.0litre fe3n factory bottom end
272 cams
Solid lifters crowner vavle springs
Turbonectics T04b Turbo
Link G4 Storm
044 Bosch pump Malory lift pump
Rx2 twin dizzie long ratio 4 speed pan type gear box
Hilux 4.1 diff
Mitsubishi gto 4pot brakes , factory fronts on the rear.
Custom shocks all round, custom front end, custom manifold and plenum
All work done by me except for tune and head work.
Current power is 317hp on 11psi will push around 20psi which mi friends is and he makes a reliable 290kw or 380ish hp.
Will add pics now how do I add video ?
  • 4 weeks later...
  • 4 weeks later...
Guest dohcturbo626
so i posted a few weeks ago that it was going to be plain sailing for me however a clutch fail at last drift day turned has turned into a gearbox out then a motor out (sump leak) then though well since motors out might as well put the dx steering rack in which ment new steering arms. and thats turned into new lower arms and rose joints everywhere so many hrs in workshop this long weekend fingers crossed it all parts turn up 2moro. 64312_10151532589345854_183358075_n.jpg
  • 3 months later...
