CA18DET Mk 1 Escort
QCADTA
Bit of a small update, went and got some grommets to plug the holes in the floor before i put in the best ive got off trade me yet, black carpet front and rear in good nic for only $20 :shock: just needs another lux.
and the passenger side,
also got one of these to sort the erratic idle out with the hks bov, after sortin out the wiring, and small tune, it now runs like a dream 8)
so after that i took it for its first spin in the wet, interesting to say the least, still spinning both bags in 4th all the way down the street :lol: cant wait till i crank the boost up a bit :D
  • Replies 59
Slight change of plan with colour again :lol: this will be the last time.
also made a catch for it, just need to get a breather filter
didnt like the over riders so took them off to. bumper just needs a polish.
also got round to givin the rear quarter acut n polish.
next up will be the new fuel gauge thats in the post.
well after lookin around for some front bumpersand to tight to pay what some people are askin for them, i got board and decided to make my own :shock:
had a spare rear bumper lyin around so out with the angle grinder
By qcadta
then after some more cuttin, odd bash with the hammer, and a bit of welding, i came up with a couple of these :lol:
By qcadta
then a trial fit,
By qcadta
then gave them a bit of a smooth out and close enough to finished. call me tight :lol:
By qcadta
now have the task of makin them shinyer, and makin some bracketsto hold them on. all good. :wink:
due to our inclement weather down here and resulting hail storm that left my garage a bit wet, i got the scort out while a swept the water out, so decided to take a pic :lol: fuel sender turned up so just workin out how to adapt to the old one so i dont have to take the tank out again :?
got round to fitting my fuel sender, took a bit of cuttin and a bit of welding to change it from a top level to the old escort side level, but got there in the end. tight fit to get it in the tank with it still in place but turned out all good.
and hooked it up and what do you know it works :shock:
  • 3 months later...
after gettin the hilux back on the road its now time to get the escort back on track. Done some small things, replaced the boots on the TCA's and the tie rod ends, started makin the bumper irons etc. and after gettin some rather large quotes to make an exhaust i thought f!#k it,ill make my own. so went and got some tube, bends and a flexi, and cut up my old 63mm exhaust off my old evo for a resonator and a muffler
first was the dump pipe, bit of pissin around but got it pretty spot on, will wrapit in heat wrap to stop it goin to close to things in the engine bay, probably not a necessity but will do anyway.
and got the rest made up to the diff, so just got to make that up,mount the muffler, the hangers, andget some gaskets. i can see why some notch the floor for 3" exhausts, not much room!
finally finished the exhaust today and got it in place, just needs a couple of hangers at the rear and bit cut out of the rear panel for the muffler. all good. also finally got my hand brake cables today so will press on with that next week. will have to try out the new exhaust round the neighbourhood me thinks :lol:
  • 5 weeks later...
got my hilux cables shortend and made an adapter so the escort lever would take the two cables and give me plenty for adjustment. hand brake works good = win.
also changed the top mounts to solid mount pillow balls, just had to make some bushes on the lathe at work to adapt them to the escort strut. almost like adding power steering to the old girl. have also done a few other things but will post those updates when i get round to taking some more pics :lol:
Shit weather down here today so lit the fire and did a bit in the garage. got a new mirror still in original box. cheers trade me.
made a tray up for the battery and got that all mounted as well.
another score off trade me was this hks evc 4 boost controller. only needed a loom made for it which i did yesterday.
so the list of thingd to do is gettin a little less. might chuck an electric fan on it, and am also on the look out for some pedal rubbers if anyone has any :D
  • 4 weeks later...
finally got round to makin some bumper mounts for the 1/4 bumpers i made. was a bit tricky gettin the bends right but got there in the end.
also got a 12" fan mounted, had to make some new radiator mounts for it. got it switched off a 82-87deg switch so will see how this goes for a start. made some pedal rubbers. just puttin some small finishing touches on her before a warrant check.
  • 4 weeks later...
after originally not goin to have reversing lights, then not finding any descent old ones, i decided to put the old single rally spot on the back so i can reverse down our longish driveway at night. didnt want to drill a hole through my back panel so just mounted it to the bumper. does the trick. safety first :lol:
after lookin for a gear lever boot i went to the wreckers and spotted this, looked close enough and with a small mod it fits like cock in sock. :lol: its off a holden astra. :oops:
i also rebuilt the steering rack, and steering coupling with nolathane bushes, reshimmed the rack to suit and its good as new. :D
and took it for a warrant check today, flew through with only a headlight needing adjusting. all good so just need to get it certed now, then wof sticker, rego, then drive.
havent been up to much, but gave the escort its first wash yesterday. also got the new plate on it as well just after it was registered and warranted. Still havent got round to gettin a mate to put the stripes on, but cant rush these things :lol:
Also had a slight driveshaft vibration which was only minor but enough to be annoying, so had to raise the gear box to get my pinion to gearbox angle the same, so had to raise the trans tunnel which means my consoul no longer fits, but driveline is now smooth as. But also had to lengthen my dump pipe off the turbo as the raise in gbox raised the ass of the engine as well. also had to put a rsm in as well, smaller steering wheel and lower seat height meant i could only see the speedo to about 60kph and not much of the loud dial either. :lol:
  • 3 months later...
Havent been up to much on the escort lately but have changed the colour of the front bumperettes to black :lol:
and many thanks to crazy_rich who did me a good deal on a t25g to replace the rb25det turbo whose oil seals decided to let go. :( so back to a standard manifold, s/s dump pipe and a new down pipe for the exhaust, which i some how managed to fuck up as it now sits an inch closer to the ground than the old exhaust, and a few more alterations under the hood to get things to work. :evil: one will remedy situation when one can be naffed :) been for a few short trips and is alot nicer to drive, spools quicker and no more smoke on over run = win. :D
  • 1 year later...
Shit camera pic and through a window but only one i took. Got a bit carried away and now ended up doin panel and paint again. not to much left to do, hope to have it back on the road for spring. Hopefully got a mk2 lined up as well. that is all.
  • 6 months later...
  • 1 year later...
New year a new colour. Just sorting the stripes. thinking black with white on bonnet, but also keeping orange all round. Opinions welcome. Also got another two escorts now, 2 mk2 2 doors, one a spare shell for my race one im building, already has arches, 4 link rear with watts linkage, turreted, adjusties etc but thought I should get this back on the road first.
