Posts posted by Logo
Well todays progress consisted of checking the volatge around the dizzy to see whats going wrong there...not much found its pretty crazy might just give it a bit of a wash, grinding and cutting rust, welding the cut holes, taking the seat out see how the floor is also taking some old foam deadening out
Also bought this, hopefully will show me a bit more about the car and wiring
Finally got that heater unit removed
not quite sure yet if I want to put it in the shed for later so I can put it back in at sometime or just sell it off
Took the guard off to see what lurks behind
And this is what I found, Just a bit of a carry on from the front of the wing near the headlight
Which got cut out today
Resulting hole
Don't go looking for rust...because you will most likely find it, bit of a brush down lather up with some rustkill of some type and fill the wing seam
Hand & eye sized up with a bit of hand bending, who ever said we need proper tools and machines?
Apart from that the floor and sill got welded up few small bits need to be finished but not bad might make some sill vents back in it to make it look legit
Also got a new powermax rotor to ease the start ups hopefully but apart from giving it all a wash clean all the connections maybe trace some wire
all I can think of now at the moment but if anyone knows much about wiring you're welcome to have a stab as it's not going anywhere fast
Also on agenda...find wire to connect new horn so I can atleast wait for people to walk past and toot at them
yeah I took the whole system out was gonna flush water through it but probably won't might just sell it off or throw it in the shed
Well flatmates boyfriend who is a mechanic looked at it can't do much since I don't even have a bulb tester...but he seems to think it could be the leads also maybe find some copper ones or something.
Also todays accomplishments.....finding out how to take the fan heater module out of the car...to my amazement I didn't realize that you just loosen the nuts and slide it out....should have looked first huh. But still deciding if I want to go find a heater motor to actually power it and make it work for that extra warmth in winter instead of being trapped in a somewhat small icebox
Sweet i'll go in on monday see how the pricing goes
Here are some photo updates....not much really just new coil, battery, gauges that came with the car that I forgot about, the water damage on the door cards, small sanding on the gear stick frame and my wicked draw/paintings of the mini
New coil
Engine bay (leads will soon be replaced with ones that work!
Lovely new battery so much easier to test things now rather than a jumperpack
Stamp on the door car plus the water damage so this means I have to replace the wood otherwise the doors stick out
My awesome painting of what the car looks like now....Should enter this in a kids drawing competition (also yes I suck at drawing wheels)
Dellorto carb
Also some guages the guy had in the car....They weren't even hooked up but i'll probably just sell them anyway and find a smiths taco
This is about all I've done lately just waiting for Tori to weld my car up and for me to stop being sick....Soon as the weather becomes nice too
Will finally get around to doing something maybe clean out the carb or try fit the dellorto one on or see how she sizes in there, maybe take out
the heating system still in there unless I find a heater motor then its warm driving from here on in!!
Pretty much haven't done much really but I did buy a new battery....then had to carry it home after getting the wrong bus not sooo fun
Also tried to suss out the source of where the car isn't starting which i'm extremely certain its the leads due to the fact that the lead between the coil and dizzy isn't getting any power to it at all....Bought another handbook so hopefully that one shows me the wiring loom and might begin progress on that once I have the book and funds.
Also maybe getting a powermax rotor to go in the dizzy just to give it a bit more of a reliable start hopefully
not much of an update on the car really...but I did manage to draw and paint some decently accurate by my painting standards of the mini and one the choice of colour the gf likes
Just waiting on the brother to weld my floors then I'll jack the front check the wheel cylinders and pads...hopefully not to much replacing needs to be going there...also put the back drums back together properly as I left a spring out
think i know whats going on....tried to see if the coil-dizzy lead got any spark from the coil which it didn't....so time to replace the leads! $45 to import some performance ones for the car from the UK or go to supercheap spend 80+ on them... decisions decisions
Well went and tried to start it again cleaning the plugs etc hooked battery up and tried to start it....but...as there is always a but...she doesn't want to start not even spark at the plugs so its either the cap, rotor or earthing in the dizzy somewhere
went and fitted a battery up one 530cca...maybe to much...would last longer and all but would it hurt the car in anyway? people from Supercheap were certain nothing would happen
http://www.autobatteries.com/basics/selecting.asp
from reading that I kinda feel like it would be fine...further away from the car etc more resistance and its in a somewhat cooler environment then the engine bay
Yeah i was also eyeing that dizzy up from simonbbc hope it runs well have to tell me if its worth getting
Looking for a battery to suit it as i don't know the cold crank amps and what not just wondering if anyone has a set up like this for a mini with a 1300cc engine?
Sweet ride, should tidy up nice with a bit of welding and painting. Good motor too.
Whats with it being a 63, but having internal door hinges? Had a re-shell at some stage?
Yeah was looking at that i know the doors have been changed the Wings have a fair bit of plaster under the paint. Going to sand it back anyway might be able to see if any holes were filled but its possible it was reshelled Also thinking of keeping the dark green maybe leaving the front a bit lighter green as it is now but not quite decided
Discussion link here btw!
Discussion on the Morris mini throw me your ideas and what not
craziest idea yet....cow skin interior
Played around with the non going indicator.......it now works!!! but for how long...the connection might need better tending too...
seal is a bit of a mission trying to fit the chrome surround and glass cover back on...
measured the the gap in the points cleaned up some plugs...Got given a brand new coil from the brother he was going to put on his minor
which can be found there^^^
Seems to be getting a bit neglected after his new found play truck
With the new coil cleaned plugs and original rotor (still don't know if it even needs replacing) and brand new points.....she doesn't want to go...
Back to the drawing board I suppose
Also took both door cards off might give them a clean redo the wooden card as at some stage in its life it has become wet.
Also spotted a stamp on the back saying
Fabco industries ltd
22MAR1973
Wellington
Kinda suits the non-original doors and windows tho bit more room....would be nice to get her original tho
Been pretty bored waiting for money to flow into my account so I can buy some extra parts... and a battery
sat down tried to sand what seems to be some type of exhaust paint on the grill, bout 5 hours worth of sanding
Black won't come off so I thought meh I'll see what it looks like ground down and primed
Didn't come out to bad bit flakey on the inners but hardly noticeable
Also thought the little wing mirror could do with a touch up
Not to shabby now to ask the bro nicely to use his spray gun to give it a nice black finish
Also saw the car doesn't have any horn system so I bought a mini horn to throw in till I find
some outrageously loud air horns or train siren like on Goodbye Pork Pie
But this will have to do
Also thought this would be useful and cheap
Just sold my mountain bike so there's the money to fix the front brakes and finally get her to run....hopefully
Well the points fitted quite nicely but...the rotor....seems like they gave me the 43D/45D rotor which seems to be a bit longer and completely different shape
so in a matter of seconds couldn't take the pressure and split in half....luckily the cap and the rest of it is fine.
Goodbye $20
Been looking at new 25D distributors with the electric ignition instead found a kit that has all the parts or a complete ranging from $120-$180nzd inc. postage from the UK
Perhaps in future a good investment so I won't have to push start it so much.
The cylinders took fit...even tho it was about a day to try get the pin and screws off the drum. The shoes were rather....worn to say the least
hence the box of brake parts I discovered 4 reasonable shoes to put back on.
Thinking about it now I may have to go back and look at them....May have put them back together a bit wrong...also missing a spring or 2 and a spacer
(which looks like a square of metal the guy put back in there because he lost the originals)
Well brother came around had a hack at it....and these are the results:
Bit of a cut into the floor....bout the length of the rusted seal itself
Bit more in there than I actually thought
Well he ran out of cutting discs and the welder pretty much didn't go so will most likely just be a large part of the car missing
for awhile. Hopefully this weekend or next the mig will be operational and that should solve most of the large rust problems.
Also went and tried to hunt down some wheel cylinders for the rear...Took longer than I thought to find some but Repco seemed
to know what they were talking about and I got the 2 rear for $42, new points and rotor...which also took awhile as for some reason they
had no idea what it was, same with the rotor and condenser....only if I thought of bringing the whole distributor in first.
started looking at the rust areas grinding them back to find such things as
Not to bad really from what i've seen so far. Brothers coming over to bring his cutting discs and mig to weld a new seal
Pumped the tire up so its not just sitting on its rim.
Also tried to get it started....but to no avail...Going to buy some new points and rotor for the distributor see if she appreciates the small gifts I get her
Got her home and gave her a nice clean out. Found a few beer bottles, packs of empty smoke cartons, socks, gloves, 20c and a semi scratched dvd of The Bucket list. Apparently has an A-Series 1300cc metro in it
Not to bad at first glance but soon found a few rust holes but surprisingly not to shabby.
-Rust hole in battery box
-Rust holes in drivers side sill
-Rust near FR headlight
-Rust holes above grill
-Cracks along FR wing (looks a tad rusty under it)
-Leak in FL wheel
-Broken gas key still in cap
-Rust inside passengers floor (seems to leak)
-FR indicator apparently doesn't go after guy had a fiddle
-No brakes at all apparently (came with a box of worn cylinders and valves)
-Most likely more to come
And it begins
Looked a lot tidier in person that it did in the pics
1963 Morris Mini Discussion
in Project Discussion
Anyone know an easy way to take the mini wings off without destroying them cause i'm pretty sure they are just spotwelded to the rest of the car
