bubblegoose
Posts posted by bubblegoose
then i shall get one
i want white bumpers and side moldings and i know that the factory ones just don't look right in white
some pink wheels will set of off im sure
outer casing=ground wire
ignore what i put here i seem to make things harder than they are
put it on the hoist to do a total damage assessment since purchace
drive shaft rubbing due to pooped diff mount
left outer cv clicking like a boss
gearbox rear main bearing shot
shift linkage bent (cheerios spec)
engine mount torn
5th gear syncro vanished from dodgy shift plate
thermostat gone on holiday
and im sure ive forgotten something
might just order me an mtechII kit to make myself feel better
theres not much left but its still around
how old? 3 years id be wary 4 years id look at other options 5 year+ wouldnt botherthis one will be for the clued up ones on painting.i got given a tin of international paints "interthane 990",ex army spec green.what i cant find is what type of paint it is.its very old so could be enamel,but i have no idea.any of you knowledgeable gentlemen able to help me out??
the longer the paint sits on the shelf the softer it will be when 'cured' ie i used some 4 year old 2k about 6 months ago, baked it 3 times and still to this day its a little chewy
one coat of your choice of paint then lots of spray on underseal and cavity wax
next friday (22nd) ill be heating over the bumpy things to the coast so if anybody needs anything shifting let me know
if its small and requires little to no effort then ill do it for a cuddle
by fibre glass do you mean fibre bog? either way bog right over it (after sanding and cleaning off dust)
flattening base to a 1k top coat or base coat? matting base is sometimes used in base coats to help get even coverage but base is matt/satin by on its own
adding matting agent to a 2k top coat will do look and last just the same as a premade matt paint but will be more transparrent and take more coats to cover
ie 2 coats of mipa flat black covers the same as 3/4 coats of a heavily matted 2k gloss
MIPA, the one and only
well yeah completly the wrong product for priming a paint stripped panel as it never really dries but is an etch primer that will adhere to decent sized rub troughs
dp4000 is still an etch primer
invest in an electric DA sander with a vac attachment and buy a crappy vac from the supershed etc save you 1000 hours of cleaning up
If you want to keep the car for a long time and the old paint job is that shit I would delete it
this^, new paint will only stick aswell as whats under it. But if you decide not to remove it all you can do your repair work as normal then before paint use a product like PPG DP4000 as a wet on wet primer sealer, and if you run out of time it can be painted over upto 5 days later without having to sand it back
clearly teh guvment didnt get my text, put the power of wof times in the power of the inspector.
'oh hey yours cars mint come back in a year'
'hey brah your cars a peice/datsun ill giz you a month'
150 hours is actually pretty good going for a home job well done
turn the drum brake around and put the wheel nuts back on a few turns and use the drum as a slide hammer (after undoing the 4 nuts behind the brake etc)
they do skid a little but not that bad, skinny hard tyres help with that
an e30 is my victim, obviously im not going to be firing in some random spring before finding its coil bind length etc but progressive springs eat bawls
some base coats like ppg deltron are formulated to have hardener added for use in places like engine bays to replicate the factory Durable but shit looking finish.
as for flatting 2k i would always buy specialty flat paint over flatting it your self where possible ( ie with whites and blacks and some other common colours come in matt), matting base will weaken the 2k and make it transparrent making it scratch and mark easier than straight 2k, spies matt clear is by far the best in the normal range of paints and mipa 2k matt black is bloody amazing to use
another spring question, the mod threshold says
The springs or shock absorbers are direct replacementsif a car has egg shaped springs but the ends are X diameter, can i replace them with a straight coil with the same X diameter?
wire wheel rust bubbles and dig it in to all the seams where rust will hide. smash a good coat of brunox over the bare metal patches then the next day some sticky paint like hammerite or rust kill enamel give it a few weeks for that to set then get underseal happy. good idea to brush some into the seams the day before you paint the full underbody
PAINT THREAD
in Tech Talk
resene durepox 2k
tough, flexible and comes in satin black
