bubblegoose
Posts posted by bubblegoose
pretty sure ive got it all figured out not fwd 4g63 with flywheel and clutch from rwd 4g63 (l200 maybe?)
smash shit out of fire wall
fit horny ass R1 carbs
figure out ignition system
ha i could convince my self its easy
let me guess bash the fire wall for the water outlet?
id roll out to that my car ain't the prettiest but id take it anyway
cheers for that
ive read all the stuff i can find on swapping the motors but my heads not on right this evening and just wondering if somebody could confirm what im thinking.
its a 1979 lancer thats had the 1200cc and 4spd swapped for a 1600 and 5spd (4g32?) looks to have crossmeber swapped not modified as i can see clean paint where the old one was bolted
im wanting to drop a 4g63 dohc in the hole and as far as i can work out i can use my 5spd from the 1600 as the bolt pattern is the same but the motor i have is from a fwd so i would need to get a flywheel from a rwd 4g63, are all rwd the same? and for the clutch i would have to use the pressure plate from the rwd motor but are all the friction plates the same spline pattern and diameter?
i know this has probably all bee covered a million and four times but ive read all my eyes can take and just want to double check it all
been told that starion struts will fit
do i need the whole strut assembly or can i get away with just the hubs and brakes
also any easy upgrades for the rear?
there is the old landrover trick i picked up in the uk when the start to knock you put a the foil from a packet of smokes under the lower half of the bearing solves the problem for a wee while haha gets another 50,000miles from a discovery
www.themopedjunkyard.com or it might be www.mopedjunkyard.com
i cant remember
they hooked me up with a big front facing carb
80ccbig bore and race pipe for my puch maxi
that was a mentle little ride after a little porting and carb setup
Cars you own: 1979 lancer, 1993 primera runabout
Mods to them (can be brief or detailed):lnacer- stripped stripped and more stripped fixed bucket seats back lowered on custom leafs (the rest is still to be done)
Link to pics (if you have some, and keep it a link to keep 56kers happy)
How you found out about oldschool: looking for lancer parts on google
Anything else you want to add: yeah i need lancer parts
Gen 1 lancer brakes, diff and engine upgrades
in Tech Talk
hmm megasquirt looks pretty cheap, are they easy to build and tune?
also anybody had any experience in firewall modification and getting it past cert
as i was tinkin maybe cut the middle out and weld in a new section set back a few inches rather than doing it properly with a hammer
