Posts posted by escort74
Right so I have a Mk1 escort 2 door. It has the larger top hat. I want to fit roller top hats and need shorter inserts. Anyone know what the best options are? Have used the search function but some of what I've found is neither here nor there.
I was considering ordering the tophats from burton but if there is a better option?
Im running them on my daily Mk1 four door , currently have moved them into my racecar for the cert . I can post picture if you want to see them
Kemp Road (waiuku) Hillclimb run by the MG car club
Line up of Escorts
Mine - Pinto powered
(red one) Bills - Pinto Powered
(green one) Dav's - Crossflow Powered
(blue one) Marty's - Crossflow powered
and on the last run this happened
The exhaust got pushed into one of the 4 link bars and put it a bit out of shape
Guards cracked from the impact
rear panels got a few bumps now and so does the rear quarter
luckily the rear tow hook took most of the impact
and sheared off
- 5
What mirrors are those and where'd you get them? They look good.
Cheers ChrisK , here's the link - they're just from trademe
http://www.trademe.co.nz/motors/car-parts-accessories/performance/other/auction-1008071995.htm
It'll definitely get lots of use and be out and about when its all finished VKzac and check out the new post Mof
Found the reason the car wont turn over
Lack of clearance between teeth on flywheel to starter motor causing it to bind
Made some mods to the starter gear
Turns over but but wont start properly
checking over the carbs and found the accelerator pump assembly had come apart
Back together again
First start up....finally
- 16
escort74's 1974 Ford Escort Mk1 - Project Alan Mann
in Projects and Build Ups
Dropped off to the blasters
Cant wait to see how it turns out
