Posts posted by fishtailfred
Did I take any? Hmm, if I did, I will post up, I still need to post the last ones. I guess the moral of the story is that if you wanna see the scene, be there!
Yep, just about to try to fire up a silvertop 4age on an engine stand in waiuku too
And 21 datalogs in probably around 10 short drives later too
For Slow'n'low, Cam, Ned, and any other geeks!
There were a number of issues, some subtle, some obvious, some 3 years old, some 3 hours old.
1) That logic for "self set" was backwards, once reversed it had a nasty miss and then pulled to redline/the sky
2) I found a corner case in the scheduler where if overall advance = 0 (inclusive of engine offset and timing and cylinder offset) then no output event would be scheduled (we weren't hitting this, though)
3) The logic for self sched was wrong due to using a 2 bit mask to *TRY* check two conditions at the same time, I've split that into 4 or maybe in future 5 end points now instead of 2 before.
4) Added a feature to add an extra scheduled event if swapping events out from under the decoder such that one would be missed, BUT, got the var in the setter condition wrong, completely wrong, and didn't notice till just a while ago, when I did fix this, it ran/runs MINT.
5) Swapped order of register fiddling to match other code part (unlikely to have caused any affects, but consistent now)
The above took 48 hours, total, sleep, shower, etc. Now it's rock solid!
Tomorrow I might run a silver top 4age and/or a 1uzfe both on engine stands, if things go well.
If I haven't killed myself, the engine, the car, the circuit board, got arrested, whatever, and if it's on the 13th, I'll be back one last time just before I fly away to a bunch of freeems geeks and my beautiful girl
Fred.
Great to meet some new faces this time
Sorry for the 3800rpm rev limit and associated lack of burnouts.
Thanks for the burger, Chris! Most appreciated!
Someone said the next one is on the 13th? If that is true, I fly out two days later, so I may be able to attend that one too, I figured I'd miss it, though. Time will tell.
Fred.
I can/will bring my fancy camera and probably a spare battery, if I get my shit together in time...
This is my last meet for a few years, guys, won't be at the nats this year, will be thinking of you all with love from Spain unless my relationship goes tits up.
Fred.
and there won't be a FreeEMS car there unless someone with a B6 or BP car wants to wire their engine up to a db37 with my pinout and let me tune it for them briefly.
I take that back, FreeEMS will be there! In almost-OS style, no less
Fred.
I'll be there for sure, unless I get busted on the way OR BLOW UP THE ENGINE AGAIN.
Fixed
I'll still try to make it, but the ute won't be there, and there won't be a FreeEMS car there unless someone with a B6 or BP car wants to wire their engine up to a db37 with my pinout and let me tune it for them briefly. Any takers? Orion? Thought not. I'll bring the latest souvenir along for a laugh. This engine just didn't handle the torque/boost/power, unlike the last one, which I killed fair and square! This one would have died on MegaSquirt if not for the gapped down plugs which we opened up about 10 pulls through 3rd ago...
Bump: I updated the first post, removed the picture of my gay old MS2 box and replaced it with my Puma FreeEMS box! NEVER will I run MegaSquirt on ANY vehicle again, period. FreeEMS for ever!
Fred.
The ute was sideways wildly a few times today, and no MegaSquirt was in sight. It's faster than on the MS bad/2.0 tune now, with NO tune. here is the no tune that its running on:
http://stuff.fredcooke.com/FreeEMS.untuned.map.ftw.png
Literally untuned!
And rapid!
I'll try to add a few more features and get the tune smoothed out a bit before the meet, but:
I'll be there for sure, unless I get busted on the way. If anyone wants to checkout what FreeEMS is like and can do, be there!
Fred.
It's running like a bag of shit for several reasons. It actually drives smooth/fine below 2k and the timing falls on its face above that, and I know exactly why and will fix it tomorrow with some luck. I like the way it spools up at 2k in neutral, though
Needs more tuning, and the exhaust leak fixed, and a few other niceties
Fred.
Depends on the input pattern it has. Most Toyota engines use a dual VR setup. To use that unmodified you would need to add a dual VR conditioner such as the one jbperf.com sells (Jean is a good guy). However you could cut a single tooth off of the 24 and get a 24-1 and run that for COP/Sequential or 24-2/12-1 by grinding two off and get wasted spark/semi sequential on the built in (by me) VR conditioner. I don't know what old toy motors use, though.
As for me doing it, I've got too much to do, sorry. As per the thread I can provide info on my mods and setup, but not much more. It's very easy, though.
The burger is for the "FreeEMS - that'll be ready in 5 years" comment - how is 2.5 months?
As for the "right price" I do want my money out of it, it's worth good cash, and I need that cash to survive while I work on FreeEMS and prepare to either get a job or leave the country (or both). 400usd which is what, 500 or 600nzd? gets you the same thing, without customisations, from diyautotune. If you look on trademe you find v2.2 boards with ms1 cpus for 500ish. Be careful to compare apples with apples. The for sale thread is dead honest. I could have not mentioned the negative stuff without being dishonest. A lot of it is true of all MS units too, anyway.
MS2 has a lot better performance than MS1 and the V3.0 board is a lot higher quality than the 2.2 board also.
Fred.
Maybe around 200nzd or so? Hard to say. It depends what you need on your setup.
http://forum.diyefi.org/viewtopic.php?p=13349#p13349
^ this thread might be a clue about how the Puma stuff is going for me
Fred.
If any mitsi or mazda owners (or anyone else also) want an MS2, I could bring mine along for the right price
Fred.
Chris, if I manage to show up, you owe me a burger
Got some software issues ironed out tonight
Going 4wding till mid day sunday, will be trying to run ute on FreeEMS then. It should run better with a good EMS and some tuning
It'll be nice to see the back of the MegaSquirt in the knowledge that the new EMS can only ever get better and better
IE, I'll be there on FreeEMS this time, or I'll set off the night before and fucking walk.
So if she makes it i expect a big Burnout to welcome her back on to the road!
Quoted for truth! Can charge batteries and take HD footage this time....
Man, that sucks, rego?/photos?/better description?
Bummer about the stagea/key situation too.
I took a handful before my fancy camera ran out of juice, I don't think I took any with the little camera, maybe one or two. They were mostly Puma related, though. How do you want them delivered, or shall I just post them up once I get them out of the camera?
You could always ask zep to change it, he can you know
Twas a good fun night!
Thanks everyone!
Apologies for the missing and bogging and generally shitty running untuned/bad tuned ute...
Managed to pull out to the revlimit in 3rd a few times on the way home, but it was hesitant as fuck...
Clearly needs new engine management
Tomorrow, if I CBF, or maybe a few days later.
Fred.
Awesome! Old rides not required
Got code running on mine today!
More mods and checking to do, but getting close to usable!
Black boards aren't too hard to trace traces on, only where the white silkscreen is on top of a border between trace/not is it hard. Granted it'd be easier if it wasn't this way, but it's still not too bad IMO. And I'm a noob, so...
phr34kr - anyone got a phone number for this man? land/cell/both? I've not heard anything from him recently, either that or my memory is completely shot.
Fred.
Fuel injection timing range and OS engine max timing figures
in General Car Chat
Are there any hardcore tuning gods on here? And by that I don't mean tuned half a dozen 1uzfe setups, I mean tuned 50 1000hp evos/1500hp skylines/supras, etc
Or just anyone with good theory or practical experience tuning injection timing on a variety of engines.
Staged injectors with large distance to the intake valves? Someone do the math for me?
Rotaries, how much timing do they like in different areas? NO idea...
Old hemi non quench engines that needed lots of advance, and then if you went 1 degree too far exploded? How far did they need to go?
You might want to inject aligned with intake opening or closing and build backwards or forwards from there, but how much would you want to change that timing over the full operating range of the engine?
How about siamese injection for austin/? A series engines, any knowledgeable people on that here? (same goes for buick straight 8 too)
For anything mild like my ute or less, or even more, just dumping fuel in whenever is more or less fine, but for extreme stuff, and esoteric niche stuff like the A series engine and injectors that are outside the throttle plates, etc, timing is important. Tell me what you need from a user perspective.
If you're interested in the gory details, here is the thread:
http://forum.diyefi.org/viewtopic.php?f=8&t=1104
Fred.
