Mr dori
Posts posted by Mr dori
After some rubber engine mounts around 70 mm in diameter with a 10mm stud on either end. and need to to be fairly short in height, like 30-40mm? any ideas
Any of you buys work at repco that could suss me a staff rate, the cunts wanted 61$ each for some ford ones that looked about right according to one of there books
FWD and rwd offsets are quite vague!
i think atlease 15offset for rwd, even then that doesnt sit out that far,
14x7 0 offset seems to be about right for most of the older rwd cars.
well, any ideas where to look for wide ones?? im all outa ideas!
Where have you guys found you wheels???
well, basically just want a half cage/rollbar as i will be doing mainly open days and car will be for road use,
I can weld and have alot of gear to make one up, so i could knock up a 4 point cage for 2-300 i would think.
Really just want something to do and why pay someone to do it if you can?
yea for sure! might go on the wagon with spacers!!!
well ive never seen these before aye, so i might hang on to these ones
yea they were off that liteace,
Worth anything you rekon:??
ive actually got some wheels the same for my model and the box says Equip 3 negative weird...
the 81 stamp must be the date they were made?
Yea they were on a van up the road and i spotted it on trademe, and the guy that brought it sold em to me for 150$ so not to bad, not overly wide tho!!!!!!!
Hey what sorta things should i look out for when atempting to build a roll cage?
Basically i can get a hoop bent up for f all and just run straight bars from hoop? what sorta steel etc/
hehe were on a liteace van! if anyone has some more rwd 4x114 steels i could buty as sacrificial wheels ill be keen!
Anyone know what these are? they got 81 stamped in back and are 14x6.5 +4
ah yea ill ask pap
I stripped my parts car and wondering who to call to get it picked up, not to keen on paying tho
yea buddy club p1!! looks cool old school dish mang!
oh mum look!
ah steering arm fits the GX ball joint aye, the strut sits forward on the steering arm so mor caster.
Im gana weld the threaded bottom bracket onto the JZX strut tube and redrill the strut tops so i can start to mock up the struts, the tie rod taper is different so ill have to find a tie rod that works, but its sweet cause jzx steering arm is like 30mm shorter so steering will be faster and more lock!
paid 1100 for the motor from a wrekers aye, its came with all the bolt ons as some people dont have alternators or powersteer pumps etc..
Um for other bits its been 1000 for fly and bell, and 550 for cluctch kit.
Fucking adds up aye
FEnder mirrors are sweet man, they actually easyer to see aswell, heaps better
Trying to mod these to fit as theres not alot out there for older toyotas
Go coilover in the front, with around 6kg front 4 kg rear, go to a suspension place and ask em to find insets or shocks from a hevier car
2x2 1/4" merging into one 3" if you wana go single pipe, 4-1 would be ideal depending on how much room you got aye
shut up pies boe, shell be going by the next track day for sure.
just needa suss afew things aye, then wire the bastard up with a link.
ah 80bucks will be sweet
O.k time for a update,
Ive got a custom bellhousing from a1 turbos, w57 box with a front shift (i need a rear position).
got a billet flywheel to suit 9.5" clutch, also got a exedy pink tuff 5 puk clutch kit.
Ive decided to make new mounts on the crossmember instead of making new ones from motor, by using the factory cast alloy ones, it looks like it will be easyer and will look abit better and will be sitting the motor vertically on the mounts rather than form the side, hopefully works out..
Also brought brand new BC coilovers for a s13 that ill adapt onto the jzx81 5 bolt struts that im putting in, felt weird cutting up brand new coilovers!
Ill keep the rear 4 stud as to use all the 4 stud wheels i have, but im think a 6.5" wheel isnt gana be enough grip 4 a v8.
decided to just keep it white as i CBF going hard out on body owrk incase i stack it or something, good thing ive got like 3 sets of everthing!
Would love it to look like this!
engine mounts
in Tech Talk
haha cheers bro, yea i know Al and fuel work at car places!
