Posts posted by 510WGN
I'd never go as far as saying I HATE rotaries either! I have FULL respect for ANY engine configuration/type that can create a heap of power!
Just that it seems these days that all RWD Corollas came out from the factory with a 12A or 13B option!
Been there and done that!!
*yawn*
ANOTHER KE30 with a rotary... that'd be different!
I've just voted for the 6, just hope it gets a heap more votes before it closes!!
OK, after being frustrated by the blue one.
It's a 1971(ish) Toyota Corona Hardtop.
Could've asked me about that one, I had a 4 door RT84 Corona as my first car. (Yeah I have owned Toyotas before my Datsun/Nissan days!
) Had the same front end as that, it had been owned by a couple from Day one so was MINT AS! Wish I still had it actually
It's not always the extra rpm that makes the flywheel exit the bell housing, too many people take too much off them thinking that lighter is better!! BUT when you get a crappy cast flywheel that now has most the strength removed to make it lighter, then give it high rpm and a some heavy loading on the clutch it can just fly to pieces. I'm not a fan of lightening cast flywheels, prefer to do the job properly and buy something like a cromoly flywheel that is light AND strong.
I jammed a cromoly flywheel in the Primera when I converted to manual, it did cost me about $500, but it dropped the weight from about 8kgs to 4.5kgs! I also now know that I'm never going to have any flywheel issues now or in the future!
The Datsun 1600 (510) was released in 1967, with the coupe version being released a year later in 1968 but I couldn't tell you when production finished but at a guess I'd say early to mid 70's.
Pretty sure they went up till about '73.
I've only seen up to '72 here though.
yeah if it's a pinto 2L sometime no.4 cyclinder suffers from a bit of heatsoak. Some people route a water outlet from the drain hole in the block to fix this problem.
Yeah is pretty common for any engine to damage the rear cylinder first as it's further away from the waterpump and radiator.
The Waterpump problem is an easy fix, just a matter of buying a new pump for either the L200 or L300 engine. Then it's just a matter of having a bit of a play with the other piping, which is really easy.
As for the intake manifold having the Throttle body facing the firewall, is easy to get the throttle body mount cut off and tig welded on the other end of the manifold.
Does anybody know if the later EVO intake manifolds will bolt up to earlier heads? Because the engines are now on the RHS of the car the intake manifold will have the Throttle body on the correct end for your application.
Is the No.4 Spark Plug all oily looking after running? The oil you added in there has just proven that the rings are a bit sad on that cylinder, that's why I asked if it has been hot. Don't NORMALLY get rings so different on just one cylinder if it was just wear, more likely that the engine has had a bit of a cook up and possibly nipped the piston in the bore, so could stop a good seal and allows the oil to pump up the side of the piston which burns HEAPS of oil. OR it could just be something simple like a broken ring or two.
Let us know if it clears after a run.
Umm, oil smoke IS white!
What were your compressions? How much lower was no.4? Has the engine been hot? How long have you run it like that for?
I've been a Diesel Mechanic for 11 years
Sure helps when ya wanna build a car though!
All the 4G63 blocks are the same so DOHC shouldn't be a problem to fit if you don't want to use a SOHC.
One of my old flatmates had a SOHC 4G63 in his Galant Colt, and another old flatmate had a VR4 4G63 Turbo sitting in his old GTO, so they all WILL work.
Cars you own: '71 Datsun 1600 wagon from the States [510WGN], '73 Datsun 1200 wagon [DOCNZ] & '92 Nissan Primera
Mods to them: Primera is lowered on 18" alloys, Strut brace, Tints, Sounds, Cromoly flywheel, HD Clutch, Few other lil bits and pieces...
1600 is in the build, will have my own custom SR20DET, some form of gearbox, 9" diff, 4 link rear, adjustable suspension, 17"x7" & 17"x10" Simmons FR17's, Full roll cage, etc etc etc, will one day find it's way to a drag strip...
1200 is FULLY standard at this stage, might also stay this way.
Link to pics:DATTO 1600 AND PRIMERA
How you found out about oldschool: Saw a link in somebody's sig on NZPC Forum
Anything else you want to add: Yeah, if you are a Datto fan then come and check out the DATSUN OWNERS CLUB OF NEW ZEALAND
Yeah but they aren't exchange mounts, they just fill your old mount and send it back, the front one for the Primera was welded to the North South beam so had to be sent up with it. Was a real mission for them to stick it in the oven type thing they have cause of that, but I'm not complaining about the cheaper price!
Shit sorry! From what I've seen they seem to range from about $80 - $120 each, probably pay to ask them first!! My Shitty Primera ones were cheaper than my boss' Anglia ones for some reason! Thought mine would have cost more cause they are way bigger!
I cant see this as a good idea....
Nolathane is sposed 2 tighten up your suspension, putting urethane in ur mounts will tighten them up, putting all stress str8 into ur chassis.
Unless its a different grade of urthane
It seems like exactly the same stuff to me... BUT... They do cut little gaps in them so it isn't TOTALLY solid! My Bosses Anglia went through for Cert with those engine mounts in there too. Is mint to drive, just notice a small vibration into the body when starting, but otherwise isn't harsh at all.
If you are all too scared to use them then no point bitchin about it!
Yeah just look up BNT in the phone book, is one on pretty much every decent sized town!
Will have the prices tomorrow for ya...
Oh yeah, so there are at least 3 240Ks around that I know of then, wonder how many more of them are around?... They are COMMON as anyway!
If any of your old Engine Mounts are stuffed, take them to your nearest branch of BNT and they will send them away to be remade with stuff like what the Nolathane bushes are made of! This is WAY stronger than normal rubber so perfect for when thrashin your oldschool ride.
They can do pretty much any kind of mounts - I sent my two mounts on my North South beam in the Primera away to get done, just fitted it today and WHAT A DIFFERENCE! Hardly any flex in the mounts at all! They did put a couple of cutouts in the mounts - even though I asked for SOLID mounts
But it doesn't seem too bad as it is.
I'll be sending my old 1600 mounts away soon so they are all ready for the extra power of the SR20.
My Boss has had his old Anglia ones done too after his 1600 engine kept breaking the original ones.
Will update when I find out how much it actually cost me...
Does Anyone know where that 240K is from? Looks like one from here in Tga. Is it on the road yet or was that a pretty recent photo?
Was wondering why there were so many pages about peoples ages!!
I'm 26, glad to see I'm not the only oldie here!!
All the piping?? What are you up to man??
Yeah all those utes and vans hold a huge price aye! I'll need mine for towing the Datto around NZ events etc. Will still have a few mods
Will have to be a diesel turbo engine though.
Well I've had...
'73 RT84 Toyota Corona
'82 TA63 Toyota Carina
'72 P510 Datsun 1600 Sedan
Now have...
'71 WPL510 Datsun 1600 Wagon from the US
'92 P10 Nissan Primera
Soon to come...
'95-'00 Nissan Caravan for towing, daily driving and the odd mish!
Yeah seems pretty common for people to mistake a Galant Colt for a RX2 and the GTO as a RX3! I think there are just too many try hards out there that try to show they know everything about Rotarys so others might think they are cool.
They just make themselves look SOOO stupid in the process!
HOW TO GET OUR MONEY FOR TRACKDAY BACK OFF DETON8!!!!!!!!
in General Car Chat
SHIT! Did this guy give you all the run around?!? He kept posting on our DOCNZ forum a few times to try to get some of us Datto folk along... but most of us have no money and cars in pieces so didn't even reply to him. I could try to contact a few DOCNZ members about him, cause I'm sure he was contacting them about other things...
