Posts posted by ranton
i got two machines in penrose pm me
Basically whats left...
- change cam-belt and waterpump
- machine chamfer on to bottom pully to accessory belts can be install removed without having to lower the engine away from the chassis leg
- install front mount intercooler
- plumb up intercooler piping.
- plumb up cooling system
- bleed up brakes
- make new hydraulic line for the clutch pedal.
- setup coil-overs correctly.
- re install dash etc.
the body will stay rough for now.
Well its been a little while since a update, purely because of my lack of time.
- Engine is back in, starts and runs too... exhaust is too quiet... despite no mufflers... lol
- Cable shifter mounted
- Braking system (new lines)
- Fuel Pre supply pump installed
- Wiring (integration) of factory EDC15 Management complete
- Interior carpets pulled out and cleaned thoroughly
- Central Locking installed
- 2.5 inch Downpipe and Straight pipe exhaust system made.
- engine bay painted - cheers tyler.
Downpipe
Carpets stripped out
Door cards painted.
Currently pricing up a engine upgrade kit.
Now would be the time to do it before I bother making custom piping etc..
The stock power of the engine is "100hp" 250nM
The small hardware and software upgrade would bring around 230hp and 500nM to the table.
just trying to do the numbers to see if I can make it stack up financially.
Well since my last post, I took some time off to focus on the finer things in life... aka i was busy doing other shit to spend any time on this little nugget.
any who cracked back in to it the other day. this is the progression of progress since then...
Assembled and installed the new sub frames, adjustable suspension, brakes etc to get the chassis rolling again...
Test Fitted the newly painted wheels ta-da she rolls again (big whoop i know) now my hoist is free again.
Proceeded to test fit the new heart to make sure everything clears as it should, and to help visualize where everything will live..
sits in there nicely but unfortunately the engine cover will sit to proud to allow the bonnet to close, I CBF dropping the engine down (as the sump is low as fck any way)
Few changes here and there, what to do with the Oil cooler, intercooler options water to air vs air to air etc...
Have started merging the looms and tidying them up in a braided type cable conduit.
The engine came back out again obviously too, far easier to work with it out.. plus the bay is getting painted this week.
ECU will sit nicely in the Rain Tray here.
Also powered up the ECU and ripped the standard mapping off the car and have now flashed a 140hp base map and will work on adding in things like Launch control etc with the tuning software later.
Quite cool what you can edit out of these ECU's
Few more annoying little jobs ahead but its really not all that far away from key turn.
- Installing the Pre supply pump and wiring.
- installing shifter mechanisim
- fabricating downpipe
- sorting out cooling system etc
- 9
Ahhh good stuff! The old diesel 1.6 is certainly no speed demon.
Damn those 1.9 tdis must be hugel tunable!
Is that mikes set up for sale?
Also on your firewall youve drilled the holes for the clutch master cylinder, what one are you using?
Currently doing a freinds 1.8t swap and doing the same thing.
Hes using a mk3 clutch pedal
Mike will sell his for the right price.. his motor is ridiculously low KM thou also.
like legitimately the car he pulled it out of only had 38,000km
from experience the MK3 pedal wont work all that well without a whole lot of fucking around. cutting and welding
I have a Corrado/Passat Pedal box.
But I will look at making a simple custom setup as the Corrado pedal box is getting rarer/ and way to fucking expensive for a shitty 20 year old part.
a MK4 Clutch pedal might be a go as it is a Standalone unit,
the other setup that is good is the cable conversion hinge for the late gearboxes.. that way you can stick to the factory pedal box. but only real issue is that is pricey as f*ck also.
I have a whole lot of fucking around ahead to make custom engine mounting brackets. its not hard but just a fuck around to get 100% right.
Bit more necessary but dumb shit today.
Mounting the Electronic throttle to the Pedal box.
The E-gas pedal and bracket to be.
Where the pedal needs to end up.
Bracket Mostly made and welded to the Pedal box.
Calipers are all done in Retina burning red!
Also started on making the Gearbox mount, when i say making I mean measured and cut the steel ready to draw and cut the template on to them.
Dream build of mine! so damn sexy
Did you just have a 1.9tdi lieing about?
What are you doing with the old parts/injection ?
Old engine is sold, old engine was just a 1.6 non turbo (bit of a snail)
I bought a low milage Generation 4 Golf with a 1.9t PD engine in it. its only 100hp but will computer tune to 150, if i did a turbo and injectors it would easily make upward of 250, some and with more tickling 400hp. but will stick to 150 for now.
Thats the engine conversion i would love to do into my mk2
My mate has a 1.9 with a VNT turbo. and gearbox for sale
Bit of Cleaning, and stripping down today.
- Soaked the Engine bay with De-greaser and then pressure blasted to clean off 20+ Years of Grime and other shit.
Before
After
- Dash board out and factory looms stripped out, for re-routing and Splicing with the new looms
- Installed the new pedal box for the Hydraulic clutch setup
- Finished stripping off all the factory tape and hard plastic tubing.. heres the two looms to merge.
Just a few little things after work today.
Started to weed thru the Sticky cluster fuck of Modern car loom, thankfully only about 1/10th of that will remain after I am done with it
Also degreased the replacement subframes and sprayed over with some engine enamel for a quick tidy up.
Stripped the brakes off and dropped them in a tub of Phosphoric acid so that they can be painted tomorrow.
- Also ordered my Adjustable Coil-overs today
- 22mm Master Cylinder.
- New headlights.
- New handbrake cables.
- 5
The new 1.9TDI Unit Injector engine.
Got my discs back from being Slotted also.
Today after work the front came off & the engine, subframe and suspension all came out.
That was that for the night.
- Next job get the new suspension up and mounted and the body rolling again.
- Strip out dash and shitty factory wiring and begin the splicing and re-looming of the car.
Re shimmed and re assembled the transmission and did a few odd jobs on the donor engine today.
1. Clocked around the turbo for Engine mount clearance.
The turbo itself is very small but it will do for now.
2. installed the rear engine mount to suit the MK2 Platform
3. Deleted EGR and started eliminating some of the unneeded functions (anti shudder valve etc)
Also yesterday I got my new Brake discs back from being Slotted
Hey guys,
So I picked up this MK2 Diesel several months ago.
The specs.
- 3 Door, no sunroof.
- 1.6 Litre Diesel manual
- 240,000km on the body.
- The body itself is pretty mint, but the paint is shit
The existing motor is pretty well shot now.
It looks as thou someone has rolled paint on the roof and bonnet at some point in its life.
So the crux of this little fix up is
Make her a bit tidier, faster etc.
Low Milage 1.9TDI Engine from a 2003 Golf TDI
5 Speed Transmission
Quaife Limited Slip Differential.
Wide track suspension with 5 Stud conversion
Bigger brakes
Coilovers etc
Work starts tomorrow.
Although today I did strip the gearbox down this afternoon and install the LSD so that worked out good.
The engine bay as it is currently.
Yes exactly, plan is to keep it diesel (like I said, 1.9tdi). The swallowtails are the very early ones, I think up to 76, and then they had small tail light non swallowtail. This is the difference:
Swallowtail
Non Swallowtail
See how there is a curve under the lights whereas on the non swallowtail one there isn't? In my opinion the difference is so small that it's not worth specifically chasing a swallowtail, but cool if you have one. Mine is a 1980 so it isn't.
IMO the swallow tail is ukly AF
Yo man, Kieran here. Valve cover looks very dope!
As in lordes brother in law?
Cars you own: 1987 Golf GTI 16V, 1989 MK2 Diesel, 1994 Audi 80 V6 (list goes on)
Mods to them (can be brief or detailed):
Link to pics:How you found out about oldschool: word of mouth
Anything else you want to add:- 2
Can I borrow your MIG for an hour? Auckland
in General Car Chat
