Posts posted by dodgypete
I took ages building the engine and getting it back in the car. In the meantime I did some work on the interior.
I removed the shitty centre console with gauges you had to lie down to see:
I removed the shitty tread plate parcel tray. Why do people do this??!??
I couldn't even give it away in the end.
Yep, it was all crack tested. Well, except the crank. Helen Keller could see the crack in that.
May be a pinhole through the bore to water jacket?
The corrosion was quite bad. I wondered if it had been left with water in the bore for a while after blowing a head gasket.
Being a complete noob I made a couple of mistakes, but got there in the end.
I wondered if the corrosion mark in the bore was because it had blown a head gasket at some point, and been left with water sitting in it?
It is now 1310cc (had to go up a size to get rid of the corrosion)
It ended up needing a replacement crank - had a huge crack in it.
I got the cam reground to a Kent MD266 profile.
This is what happens when you try to flip the gearbox over by yourself to bolt it onto the block, and drop it on your arm:
I fitted a lightened double row timing chain and checked the cam timing. It was retarded by 7 degrees!
Ended up fitting an offset woodruff to get it right:
9
I took it into what turned out to be the most expensive engine reconditioner in town. After the price estimates kept getting higher, I told them just to do the machining, and decided to have a go at rebuilding it myself.
This was pretty daunting for me since I hadn't (and still haven't) replaced a wheel bearing or ball joint etc. Might as well start with the hardest job!
5
The pics I've posted are from about 2 years ago. The mini is already back on the road, heaps more updates to come.
Well, the engine lasted about a week before smoke started pouring out of the rocker cover.
After a compression test it looked like the rings were gone on cylinder no. 2.
I pulled the engine and took it apart to confirm my suspicions. Sure enough, both compression rings were broken, and there was a nasty corrosion mark in the cylinder.
I've been lurking around here for a while now, so I thought I better start a thread on my Mini.
I've got a heap of photos but they won't load properly. I've uploaded them to iforce.co.nz and followed the instructions in //oldschool.co.nz/index.php?/topic/34643-how-to-add-pictures-to-the-forum/
If I put my image link in between the img tags they keep changing when I click preview and I get this message:
You are not allowed to use that image extension on this community
Help? Someone?
Discussion:
//oldschool.co.nz/index.php?/topic/53286-dodgypetes-1980-mini-1275gt-discussion/
Harewood Vehicle Inspection Centre
580 Wairakei Rd
My Mini flew through its WOF there.
dodgypetes 1980 Mini 1275GT
in Projects and Build Ups
Then I removed the shitty seats.
The front seats had some pretty dodgy frames under them.....
