hr31gts-x
Posts posted by hr31gts-x
Most recent thing i have done is a 5 stud swap and R32 brake up grade.
This is my 1986 hr31 coupe project. Iv had the car for about 6 years now and been plagued with problems ever since buying it, but havent given up yet. As it sits it has an R32 rb20det with front faceing intake a Turbonetics T3/T4 a Megga squirt ECU,GTR 440 injectors and all normal bolt on junk. When it gos it gos pritty good was meant to be makeing just under 400hp at wheels at 20psi acording to tuner who did ECU install.
Im not 100% sure but didnt some austin healey's have two steering box's? i remeber my dad saying the steering was a funny design on them.
I would look in to WW2 era armoured cars as alot of them had very strange steering box and sometimes more then one and they can be made road legal in NZ. My dad is in military vehicle club and there is some very strange designs that are road legal.
True i had always thought the s12 rear was pritty much the same as an hr31 i should of had a better look at my mates notch back s12 when he had it.
The z31 5 stud hub is same size as the 4 stud r31 hub but the splines on the z31 hub are lot bigger, it seams all IRS r31's have small splines turbo or not but i got the z31 chapion flanges with the hubs that are same 4x1 bolt pattern as r31so wasnt a problem.
Im runing r32 gtst disc's to match the caliper as the r32 disc is same size as my old turbo r31 disc just 5 stud.
I know lot of people have done this conversion but nobodys said on any forum's how thick the caliper spacers nead to be. I Have just been useing washers to pack out caliper but havent found any that get it centered yet.
Thanks for your input.
cheers mate,
yeah, was a bit of a struggle getting the wheels on there...
back end was easy, just used Z31 300zx stub axles in the original rear arms. changed the rear drive cups from the 3x2 cv type
to the 4x1 bolt r31 turbo type, as these axles/cv's are much stronger and fit straight into the r200.
the rear rotors are also z31 turbo. it turns out they are the same diameter as my originals, just 5 stud.
it looks like the rs-x model got a lot of the good bits off the bigger cars.
fronts proved a little more work. i already had coilovers, but the original 300 lb springs were a tad too soft and short in length, which resulted in the coils binding before the strut ran out of travel. not good! sourced some 350lb springs in a longer flavour, which worked a treat to start with. it meant the platfroms were wound right down to get the right height which resulted in the springs chewing out the threads of the adjustable seats.
started over again using R31 turbo skyline struts from an import, which mean they have slip on hat type rotors(easy to source) and 4pot
gts-t calipers bolt straight on (which will also fit under the wheels). they have a short tube to start with so even lowered have plenty of travel.
i had to remove the stock spring perch as its right where my tyre would sit. all of the coilover hardware i used came off an s14 set of tein coilovers which had rooted inserts. machind off the threaded tubes and welded them onto mine.
i had to use a shorted gas insert shocks, koni's from what exactly i cant remember, as jap R31 inserts arent available here
it worked out sweet as the teins run short springs with keeper springs, so "heaps" of tyre clearance(ish).
i tried all sorts of front hubs but settled on one of these 2.
the factory 5 stud z31 hub works, but would need machining to get a slip on rotor on them, and the push the wheel 12mm further out than the r31 turbo one i used. so i got the engineers at work to redrill them for 5 stud.
fitted on using late 300zx discs (i think!) and used laurel front calipers.
after sorting all that, i wasnt happy with the wheel studs. z31's have the fucking shortest wheel studs ever! like 2 turns of the nut on the watanabes was all you'd get.
took a while to source the correct one to replace with and $250 bucks later, i had to cut them shorter as they were all too long. gah...
finally all together and in it worked, but had to run a small spacer in the fronts as clearance is so tight that the clip on tyre weights had to come off as they hit the strut when they spin past.
easy really.
would NOT trade again
Hey did you have to use a spacer on rear calipers to fit them? Im doing a Z31 5 stud swap on an Hr31 coupe. Im haveing problems centering the r32 2 pot caliper on to the disc its looking like i nead to make up some spaceing washers. Did you have the same problem? any help would be awsome. Thanks
Havent been on here in while the y31 5 stud hubs were a no go offset was very very wrong wheels stuck out by almost 5" and couldnt get a disc to fit. So ended up finding some 5 stud z31 turbo hubs took almost a year to find some. They are same as factory 4 stud just have bigger splines on the chapion flange, so you nead to get the flange's with the hub if you do the swap.
Its a good upgrade just for the extra brakeing you get going 5 stud as im now running r32 bm44 master cylinder r32 gts-t disc's with four pots front and 2 pots rear. My coupe is top of the line factory turbo but only had one pots front factory and used to run out of brake's when i was giveing it bit of cain.
Hi i was just at smash palace aka horopito wreakers and saw one of these there very complet not much had been taken of it. maybe good for parts if you nead any.
yeah both the y31 and r31 have drum hand brake in disc. was going to use z31 hubs but they have caliper hand brake like a silvia so went with y31. alot of people have done the swap but nobody seams to have posted any info on any of the forums out there.
im converting the rear of my r31 coupe to five stud i have some y31 5 stud rear hubs and r32 gts-t brakes im planing on useing. has anybody done this before any info be handy. cheers
1986 Nissan Hr31 coupe project
in Projects and Build Ups
Will upload more pic's soon just had these on pc already.
