Posts posted by Gomaxgo
i was going to swing by today in it and as luck would have it, its got no passenger seat at the mo so the sills would have been your only option
Took it into work today to get some bits and pieces sorted.
Ended up under-sealing all around the inner rear guards and everywhere underneath i had to weld.
Tidied up some wiring and got the wipers working. Tidied some other stuff, then washed it for the very first time.
not all that productive really.... but i did get to drive it round all day which was pretty sweet
Finally took some photos too
you can use one of the links outputs as a tacho signal, i did this in my starlet and works fine.
those left hand drill bit things are pretty amazing
we get a lot of the 3.1s in at work, almost always have faults in high pressure oil system. If you do go for a 3.1, i suggest you unplug the square plug next to the throttle body that leads fact into the cam cover. When the high pressure oil system sensors go, or start to go, they leak oil back through the loom. If theres oil in the plug, its usually upwards of $800 to repair.
I think you're referring to the 3.0 dohc 4JX1, but yes, these facts are true. They are lol as fuck, have sweet power when they go though.
ah yes, my mistake
Compomotive TF??
Get a strong-arm bar on it and then slide underneath the car and use your feet/legs. Just make sure that the car is stable and not teetering on any stands etc. Must be very solid, yo.
i 2nd this, when all else fails, kick the shit out of it
i agree ^
I've got an altezza 1gfe in my wagon and it goes really well, usually pretty cheap too
fronts will, rears different. 99% sure
this thing is pretty rad man! well done
rear guards are so choice
dan put alot of work into these. was sitting there watching him.
give him a free plug if ya can Gomaxgo, needs to get his name out there a lil more.
yer man just picked it up from him tonight! he did an amazing job getting it all straight
would defiantly recommend to anyone who needs panel and paint, he is a machine.
PM me if anyone wants his number
down in chch
Cheers guys for all the positive support! I've driven it half a dozen times and goes pretty well, 154 hp of screaming 1G goodness!
a shitty phone pic while being panel and painted, note rear guard height in relation to the lines of the car compared to first pic
soooooo i better have a break down of what has been done so far...
ENGINE/GEARBOX/DIFF
The engine was a freebie from Simon. W55 gearbox and i just happened to have the correct bellhousing lying round.
There was issues with the headers fitting, BUT ALAS! they happen to fit upside down, so some 2.5" U bends were bought and some super head-turner headers were born.
But what really blew my mind was that the 1GFE throttle body points upwards....... in the same spot as the 4k carb........ with the same OD! so the factory air cleaner assembly was retained and is still plumbed up to suck air from the inner guard. Between the intake and the exhaust, many LOLs were had. Oh and it has a SURFAB flag.
I already had a link G4 storm for the Starlet, so i bought a second loom and wired it in. I can't drive both cars at the same time so one computer with two maps is perfect.
The firewall was cut and half the trans tunnel went with it. Cheers SURFAB for folding/rolling up some new ones!
I had a spare hilux diff which was shortened, converted to disk brake, with new mounts and redrilled stud pattern to suit my weird ass wheels (4x130)
SUSPENSION
The fronts are shortened strut castings with shorter shocks, coil over springs and keepers on a new spring perch. Luckily it is a late model wagon, so AE85/6 bits bolt on with no redrilling or modifying. Some camber plates up top while the LCAs have been rose-jointed, very helpful for widening/shortening track to fit wheels.
Also in the mix are some motorFIX 45mm RCAs and Hardrace caster arms.
The rear leaves have been reset 3 inches with an extra leaf for stiffness and has 2 inch blocks. Hilux front shocks now live in the back to keep things firm.
The bumpstops have been relocated due to the original bumpstop mounts being cut off due to clearance issues. The chassis rails have been notched for the diff and the floor under the backseat cut out and remade to clear the diff head and driveshaft. I swear every time i cut something out, the car would sit on another part of the diff!
BODY/WHEELS
As you can see the rear guards were cut right out to fit the wheels. I wanted to have an standardish looking body so didn't want any bolt-ons or moulded guards. Some front KE70 guards were acquired (thanks Cheerios), the flares were cut off and the stitched onto the back. I really wanted the flat edge on the side of the guards and I think it worked out perfectly!
The wheels are SSR Formula Mesh in 15x8s and 8.5s with 195 45 15s all round
So theres still heaps to do before cert so there will be a lot more pics/updates to come
Ok, so about a year ago i bought a mates 2 door ke70 wagon. It was twin headlight, resprayed tan and everything else was standard.
At the time a mate of mine simon (aka SURFAB) had a Altezza he was going to build, and a 1GFE he had no use for.....
"a dx daily that had enough grunt to tow my starlet to the track, and reliable too", things kinda snow-balled from there.
Unfortunately i didn't take photos throughout the build, i only have these which were pinched from someone else's blog.
that Facebook cruise looks amazing!
Quote- "AnY bOyz qot spaRe s3atz fOa me && mY qUrlz ??? .. F**k off my notifications bitches get your own car"
i love qUrl racers
Cars you own: Toyota KP60 Starlet, Toyota KE70 2-door Wagon
Mods to them: KP60: 2 door non drop hatch, silver top 4age, T50, hilux diff, AE86 BC adjusties, 6 point cage, Link G4 storm ECU, 13x7 revolution 4 spokes all round with R888s.
KE70: Twin headlight 2 door, altezza 1GFE, W55, Hilux diff, Link G4 storm ECU, 15x8s and 8.5s SSR formula mesh wheels... cats-eye-eating low!
Pics to come
How you found out about old school: through friends
Anything else you want to add: ....... no
Brennan's, ke70 Corolla, 3sge Beams powered.
in Project Discussion
those mud flaps better be constantly dragging!
