Sign in to follow this
Followers 0
Guest cletus
Welded strut how to
2 posts in this topic
I get asked how to do this all the time. So heres a pic and description of how to do it.
Welding to a casting or forging has always been illegal as a modification as long as the LVV cert system has been around. The instructions that come with most aftermarket weld together coil overs say to weld the tube directly to the cast hub. fail.
DISCLAIMER
This is how I recommend it is done, other certifiers may have different ideas and if you have got yours certed with it stuck together with a hot glue gun then yay for you
7 people like this
Share this post
Link to post
Followers 0
