Hi there,
Finally upgraded the candles on my 86 hilux, with hella semi sealed beams.
Feel like I've fucked at least something up.
The hella housings came with a number of tabs that wouldnt allow it to sit back into the bucket enough for the retainer to screw on. I removed those, which I'm unsure about. But it seemed like the only way to seat them.
I have installed a negative switched harness, which appears to be functioning as removing the grounds results in the lights dimming, so I think thats in correctly.
The issue is that the beams just look weird. I expected them to have a reasonably crisp cutoff, but while they illuminate well, the light fucks off in weird lines at the edges and has some dim areas. I can see much more than previously but the light pattern just looks like shit, and adjusting it against a wall is quite difficult as the pattern becomes very inconsistent at that distance.
I'm not sure what ive fucked up but would love some advice. The bulbs are narva h4.
Cheers.
