What's the guts with modifying center steering links? Is it a case of asking a tame engineer to take a look at it? I'm assuming there's a bunch of legalities around it?
The standard 2002 link is straight, like this pic
Need to modify it so it has some bends in it like this to clear the gearbox.
Pretty sure that you are in for a world of hurt due to NZ's "No welding on steering components" rule. The easy answer would just be to cut it up and make it work but I'm 99.9% sure you will never get a cert. To make a custom one without heat or welding would be a massive undertaking.
Have you considered swapping in an e36 subframe?
