Hey guys looking for some advice from anyone who’s done a Hilux diff conversion into an old Mazda 808 or RX3
The original plan was to find an early RN20/RN25 2WD Hilux 8-inch G-series rear because they’re roughly the right width for the 808 (around 1350 mm WMS-to-WMS.)
I’m now considering using a more common later LN-series Hilux 8-inch diff, ideally already with a 4.3 ratio and LSD, then having the housing and axles professionally narrowed to suit the car. Spring perches and shock mounts would obviously need to be relocated as well.
Has anyone here gone down this route?
Mainly interested in:
• Which later Hilux/LN diff is the best donor
• Rough cost to narrow the housing and axles
• Whether there are any issues with shortening the factory axles
• LVV/cert requirements around the housing, spring perch and shock mount welding
• Any brake setups people have used that still clear 13-inch wheels
• Whether you’d bother doing this or just keep hunting for an RN20/RN25 rear
I’m in Canterbury, so any recommendations for local diff/fabrication shops or certifiers familiar with this type of conversion would be appreciated too.
Cheers.
Find a diff that is commonly found, not a rare piece of unicorn foreskin.
ask yourself if a hilux is stronger than a 8” or 9” for the same hassle and cost.
can you get different ratios for the diff you choose?.
i used to use Royce Clive down your way, and there was another guy near Aronui maybe that did diff work. He did the restudding on my rx2.
decide if you will be 5 stud all round or redrill to 4 stud. 4 stud brakes like 90s Nissans with caliper equipped handbrake mechs.
5 stud you could use E series falcon stuff with the handbrake equipped calipers. Or the fancy wilwoods.
I found a narrowed falcon diff on trademe, factory disc and lsd. $500 delivered. Bargain.
I run the b1600 diff but spent oodles on machining to 5 stud , rebuilding etc with the mint 4.3 lsd. But I know it’s strong and have many gear options available.
Might be something helpful here
Justin Neil Engineering would be a good place to start for welding and machining work.
S3 RX7 rear rotors and 90s Nissan or Mazda calipers might be a good solution.
havn't actually sent my concept to Justin for a look, but the phone makes me think he knows what needs to be done, and confident it can be done.
i managed to score F series (7.5") Corona GT disc diff, but only had on axle. Justin confident the estima disc axles can be re-worked to suit.
Is the diff shop still going? He was always good for what I needed. I probably need to drop my starlet diff off again one day to get the new clutch plates installed
