Hyperblade Posted October 18 Posted October 18 I'm looking at using some Carbon Fiber Sleeves on the runners of a 3d printed intake manifold to give some strength where i need it. (believe it's called wet layup) https://www.aliexpress.com/item/1005012830581918.html I've never done anything with Carbon Fiber before. What resins do people recommend to use, and where are you buying them from? Short vs Long pot life? What other equipment do you recommend having on hand that makes life easier when working with this stuff? Anything to watch out for or consider? Quote
Roman Posted October 18 Posted October 18 Using the carbon sleeve is EZ mode compared to anything else! It's really awesome as it just kinda pulls to shape. Love it. The thing with pot life is that the epoxy goes off in the pot really quick compared to the resin that is on the part. If you lay out all of your pieces and coat them in your epoxy, you'll have about 10x longer than time before the pot goes thermonuclear. I prefer a long pot life as possible, especially if doing things in summer. Although it's sometimes annoying having to wait I prefer that to the stress of having to rush to get stuff done. I use epoxy resin that is meant for infusions (so is thin and has a long pot life) from Adhesive Technlogies called ADR243. As it was petrol/oil/etc resistant as I was planning to make a fully carbon intake manifold with it initially. I think you can choose a different hardener, and that specifies the cure time / pot life. If you are doing a wet layup with the sleeve, dont really need anything apart from stuff to mix the epoxy and brush it on. And some gloves so you can pull the sleeve tight to the shape. The best time to trim the part is when its mostly cured but still kind of a gel. So not 100% set but not sticky either. Then cut the ends with a fresh razor blade and you will get a nice finish. Otherwise waiting till its fully cured then use a dremel or a sander or cut off wheel. Razor blade at that initial stage is the best time to get things mostly sorted though. Get some good PPE because I'm fairly sure that the dust coming off unwetted carbon cloth is about on par with asbestos for fun times in your lungs. 4 2 Quote
Roman Posted October 18 Posted October 18 Ahh one other thing, get some filleting wax if you have any areas of the part you dont want epoxy to get to. 2 1 Quote
NickJ Posted October 19 Posted October 19 It makes one hell of a mess no matter how careful you are, take your time, plan everything out before you mix up and move anything from the vicinity you don't want bonded together permanently! I usually have a good supply of gloves and rags nearby and swap out often, masking tape of all the sizes for the parts you don't want glued and cardboard on work surfaces. When buying materials, consumables are often 2x the cost so use that as a guide when planning the budget, gloves, tape, acetone, rags, etc etc. For what you're doing, ADR243 (resin) and ADH140 (hardener) would work really well, my go to mix for most things wet lay. The hardener is the more nasty of the two parts, you really don't want this on your skin, it is also present (in smaller amounts) once cured so protect yourself from the dust too. 1 1 Quote
Hyperblade Posted October 19 Author Posted October 19 On 19/10/2026 at 10:07, Roman said: Using the carbon sleeve is EZ mode compared to anything else! It's really awesome as it just kinda pulls to shape. Love it. The thing with pot life is that the epoxy goes off in the pot really quick compared to the resin that is on the part. If you lay out all of your pieces and coat them in your epoxy, you'll have about 10x longer than time before the pot goes thermonuclear. I prefer a long pot life as possible, especially if doing things in summer. Although it's sometimes annoying having to wait I prefer that to the stress of having to rush to get stuff done. I use epoxy resin that is meant for infusions (so is thin and has a long pot life) from Adhesive Technlogies called ADR243. As it was petrol/oil/etc resistant as I was planning to make a fully carbon intake manifold with it initially. I think you can choose a different hardener, and that specifies the cure time / pot life. If you are doing a wet layup with the sleeve, dont really need anything apart from stuff to mix the epoxy and brush it on. And some gloves so you can pull the sleeve tight to the shape. The best time to trim the part is when its mostly cured but still kind of a gel. So not 100% set but not sticky either. Then cut the ends with a fresh razor blade and you will get a nice finish. Otherwise waiting till its fully cured then use a dremel or a sander or cut off wheel. Razor blade at that initial stage is the best time to get things mostly sorted though. Get some good PPE because I'm fairly sure that the dust coming off unwetted carbon cloth is about on par with asbestos for fun times in your lungs. That's awesome info, thanks! Quote The thing with pot life is that the epoxy goes off in the pot really quick compared to the resin that is on the part. If you lay out all of your pieces and coat them in your epoxy, you'll have about 10x longer than time before the pot goes thermonuclear. Just to clarify..., my understanding is you mix the epoxy resin and hardener (in the pot), then I think what your saying is basically apply it directly to all the sleeves, then put the sleeves on the part, as opposed to putting sleeves on part then applying the mix directly to them from the pot? I'm guessing that's because the mass of the mixture in the pot does the exothemric reaction so the higher heat means it cures faster? 14 hours ago, NickJ said: It makes one hell of a mess no matter how careful you are, take your time, plan everything out before you mix up and move anything from the vicinity you don't want bonded together permanently! I usually have a good supply of gloves and rags nearby and swap out often, masking tape of all the sizes for the parts you don't want glued and cardboard on work surfaces. When buying materials, consumables are often 2x the cost so use that as a guide when planning the budget, gloves, tape, acetone, rags, etc etc. For what you're doing, ADR243 (resin) and ADH140 (hardener) would work really well, my go to mix for most things wet lay. The hardener is the more nasty of the two parts, you really don't want this on your skin, it is also present (in smaller amounts) once cured so protect yourself from the dust too. Great info, thanks!. Where you buying the ADR243 from normally? Can't seem to find any retail places. https://adhesivetech.co.nz lists it but their consumer site https://everythingcomposites.co.nz doesn't. Quote
Roman Posted October 19 Posted October 19 Buy it direct from adhesive tech. Need to email them to place an order. 1 Quote
ul9601 Posted October 20 Posted October 20 yeah PPE especially respirator is super important. i wasn't wearing one when cutting some carbon, i was coughing black shit for an entire month afterwards. im all better now but that was 20 years ago. 3 Quote
NickJ Posted October 20 Posted October 20 Yeah, it ships as DG so get in touch with adhesive tech direct. Also for you especially, carbon dust is mega conductive and will, I repeat will kill anything electrical in the room, computers love to fry themselves. manage both yourself and your sensitive equipment carefully. 1 2 Quote
Hyperblade Posted October 20 Author Posted October 20 2 hours ago, ul9601 said: yeah PPE especially respirator is super important. i wasn't wearing one when cutting some carbon, i was coughing black shit for an entire month afterwards. im all better now but that was 20 years ago. 32 minutes ago, NickJ said: Yeah, it ships as DG so get in touch with adhesive tech direct. Also for you especially, carbon dust is mega conductive and will, I repeat will kill anything electrical in the room, computers love to fry themselves. manage both yourself and your sensitive equipment carefully. Thanks for the warnings! I have clearanced some carbon before and had the vacuum cleaner running the whole time to help limit the spread (while also wearing respirator) but not keen on doing a lot of it. I'm hoping there is minimal tidy up required. 1 Quote
smokin'joe Posted October 20 Posted October 20 havn't done anything with carbon for years, but go know a fella that can supply a fuck-ton of white lint-free rags for clean-up !! 1 Quote
