Stu Posted October 24 Posted October 24 If the width of the gearbox is an issue you can remove 5th gear and then either make a new end cover or see if a c140 cover would fit. Years ago I built a 4spd from a 5spd like this. 3 Quote
Flash Posted October 24 Author Posted October 24 Thanks for the additional suggestions @fuzzy-hair-man and @Stu. I'm currently sitting in the home office reasearching various options so I'll add your suggestions to the mix. Quote
Bearded Baldy Posted October 25 Posted October 25 How about shortening the bellhousing and gearbox input shaft? Since you do not need the space for a clutch in there. 1 Quote
Flash Posted October 25 Author Posted October 25 Thanks for the suggestion @Bearded Baldy Because the Hyper9 motor has a much smaller external diameter than the C-52 bellhousing I had considered a vaguely similar approach using a top hat section adapter plate that would allow me to recess a portion of the motor within the bellhousing. Again my solution like yours would entail shortening the gearbox input shaft as well as the output shaft on the hyper9 which measures a whopping 50 something mm long. My concerns are around the voiding of the warranty on the Hyper9 due to me hacking up the driveshaft and also the overrall cost/ complexity of getting an offset adapter plate machined up. By going down your path I might get away with just hacking up the bellhousing and gearbox input shaft and leaving the Hyper9 alone. More food for thought. 1 Quote
Flash Posted October 25 Author Posted October 25 Thanks for the suggestion @Bearded Baldy Because the Hyper9 motor has a much smaller external diameter than the C-52 bellhousing I had considered a vaguely similar approach using a top hat section adapter plate that would allow me to recess a portion of the motor within the bellhousing. Again my solution like yours would entail shortening the gearbox input shaft as well as the output shaft on the hyper9 which measures a whopping 50 something mm long. My concerns are around the voiding of the warranty on the Hyper9 due to me hacking up the driveshaft and also the overrall cost/ complexity of getting an offset adapter plate machined up. By going down your path I might get away with just hacking up the bellhousing and gearbox input shaft and leaving the Hyper9 alone. More food for thought. Quote
Nominal Posted Wednesday at 08:38 Posted Wednesday at 08:38 Maybe get someone to print you up a fake motor. e.g. ME1616 Model UNCA FSAE | 3D CAD Model Library | GrabCAD 3 1 Quote
Flash Posted Thursday at 00:15 Author Posted Thursday at 00:15 Good suggestion @Nominal. Thanks heaps. Quote
anglia4 Posted Thursday at 03:14 Posted Thursday at 03:14 Are there any options for a smaller CV? 1 Quote
Bearded Baldy Posted Thursday at 05:15 Posted Thursday at 05:15 Is there room to move the electic motor forward (as in towards front bumper) 50-100mm and then run a 1:1 gear drive or chain? Either way you have to make an adaptor plate to attach the bellhousing. 1 Quote
Flash Posted Thursday at 07:48 Author Posted Thursday at 07:48 It's worth investigating that @anglia4 thanks for the suggestion. @Bearded Baldy yep offset with a gear or chain drive is an option. I've spent the day looking at alternative motors and I'm currently focusing on a ME1507 which is the aircooled brother of the ME1616. Same power with a much smaller diameter so no CV clash issue. Being air cooled it can throw temp alerts when pushed to its limits on a hot day so I'll need to fabricate a cooling shroud with a high powered bilge pump to keep it cooler for here in the tropics. Saves me from the complexity of liquid cooling I guess. 1 Quote
Raizer Posted Thursday at 09:20 Posted Thursday at 09:20 I'm guessing you'd have already looked at the likes of a Leaf motor and box? 1 Quote
Flash Posted Thursday at 21:46 Author Posted Thursday at 21:46 Yep I have @Raizer Its a totally different beast being a high voltage system (around 400 volts) compared to the low voltage (under 100 volts) that I am designing. I'd need to put my big boy pants on to play with a high voltage setup. 1 Quote
