chris r Posted October 15 Posted October 15 This is a awesome idea and I'm keen to see progress! Agreed with dmulally, are you able to get a lighter gearbag or even connect directly to a smaller diff (rear off rav4 or similar ? 1 Quote
Flash Posted October 15 Author Posted October 15 Thanks heaps for the suggestions @dmulally. There is some good news in the weight department Damo. Last night I was sitting in front of the gogglebox fretting in the back of my mind as you do when all of a suddenly I had an epihany. Grabbed out my Moke folder and sure enough there was a copy of the official Registration Certificate issued by Queensland Transport when we did the ownership transfer back in November 2017. The certificate lists seating capacity as 4, Tare as 780 kg and GVM as 1080 kg. So old mate must have got QLD Transport to update the vehicle details after he got cert for the back seat. What a win as that gives me way more GVM than I need to cover the extra battery weight. 2 3 Quote
Crispy Posted October 17 Posted October 17 I might have to follow your path if these gas prices keep up! If you need any Moke related measurements in situ let me know. I just mocked up the front subframe in mine to get it rolling. Like most British Leyland products nothing is square or true. (And mines had a hit in the front. Pretty sure a ball joint gave up) But might give you a ballpark. 2 Quote
Flash Posted October 17 Author Posted October 17 Thanks for the offer @Crispy Murphy's Law says I've probably forgotten a measurement along the way somewhere so I really appreciate the offer and I might very well be knocking on your door somewhere down the track. Yep, I did a quick calculation based on our current monthly fuel usage compared to my roughly estimated budget and I should break even after 125 years! So in my case not so much about fuel savings but more about trying something different and learning new skills. We head down to our local beach with the dog every morning usually around 5 am in summer or 6 am in winter. It's only about a 450m walk, but some mornings we get lazy and all hop in the Moke. My next door neighbours will sure be looking forward to the EV conversion. No more being woken up by the Moke rumbling its way out of the garage right next to their bedroom window not to mention the lovely fumes it produces on full choke on a winter's morning. 3 1 Quote
Crispy Posted October 20 Posted October 20 I think those sorta wing bits where the top bumpstop bolts up is a weak point. We plate over them, to basically double skin it for a bit more strength. 6 years of grass motorkhanas in my Mini (some pretty rough ones too) and it’s been fine. Moke subframe got the same treatment and so will my Dads new to him 1275gt. The Vizard book has some info on the weak points of the front subframe and how to strengthen it. 1 Quote
lowlancer Posted October 20 Posted October 20 Your life looks fun, lots of tinkering with cool things. Wicked wee build, following with interest. Quote
Flash Posted October 20 Author Posted October 20 Thanks heaps for the advice @Crispy I shall make it so. Quote
Flash Posted October 20 Author Posted October 20 Thanks @lowlancer there is nothing like working outside your comfort zone to get the juices flowing once again. The EV kit is costly so I can't afford to make any mistakes along the way. As a result I'm spending hours and hours researching various bits and bobs. Nearly got caught out with my adapter plate thickness, but luckily I managed to catch that one while I'm still in the mockup phase. 1 Quote
fuzzy-hair-man Posted October 21 Posted October 21 I like the idea of a single speed gearbox but may not be an option. I've a nissan micra in a Mini, these fit without choping the wings but did have to cut the subframe some at the rear to bring the diff back. I think the engine and box are generally smaller than the swift so may be worth a look. An EV shouldn't need the clutch so it may be possible to chop of at least some of the bellhousing and bolt directly to the gearbox saving some length. 1 Quote
Stu Posted October 21 Posted October 21 C140's exist which might be a good option? They don't have the 5th gear assembly on the end of the box so a bit shorter. Same axle alignment as the C52 though. 1 Quote
Bearded Baldy Posted October 21 Posted October 21 Nice work so far fellow hoarder. One thing i do when trying to copy queer shapes onto another surface like that, is wipe some oil or grease onto the face of the part, that way when you get things in the way like the diff etc, there is a pattern left behind to fill in the gaps. Quote
Flash Posted October 21 Author Posted October 21 @fuzzy-hair-man... mental telepathy ! I've just been researching the RS5F30A gearbox out of a 1995-1997 Micra and it looks like it may be the go. The width certainly stacks up on paper. According to The Google the K11 gearbox measures 320mm from tip to tip. If I allow 12mm for the adapter plate and 340mm for the HyPer 9 motor that gets me 672mm compared to the Moke subframe width of 680mm. If I have to do a bit of choppy, choppy to the back of the subframe so be it as long as my driveshafts poke through the original subframe openings. I'd be keen to see some photos of your subframe mod if you have them. Quote
Flash Posted October 21 Author Posted October 21 Thanks for the suggestion @Stu. I've also been looking at the C-50, C-54 and C-150 gearbags so I'll definitely add your C-140 suggestion into the mix. I know of an EV conversion on a round nose Mini currently underway and they are using a Suzuki Swift 5 speed gearbox, but I've heard they can be a bit soft synchro wise which is a worry considering the torque that the electric motor produces. Quote
Flash Posted October 21 Author Posted October 21 Thanks @Bearded Baldy bloody good suggestion. I ended up pinching some black paint off Mrs Flash the artist and did a thing, but it was a lot harder to clean up than grease would have been. 2 Quote
tortron Posted October 22 Posted October 22 4 hours ago, Flash said: RS5F30A I have one in my deep storage shed, want anything measured? Do you want it? And the engine? And the car? You should find them attached to most not sr20 Nissan's of the late 90s early 2000s 1 Quote
Flash Posted October 22 Author Posted October 22 @tortron I'd be keen on the gearbag if I wasn't on the other side of the ditch. Quote
fuzzy-hair-man Posted October 22 Posted October 22 Here's a pretty poor build thread, but it's currently down for php vulnerability reasons. Unless you can make the gearbox more central than mine you'd need to cut out the side of the subframe. More central would be good though as it'd improve driveshaft angles and clearance for CVs. https://www.theminiforum.co.uk/forums/topic/253043-spot-the-micra-mini/&ved=2ahUKEwjAur60ys2XAxU4r1YBHdifCzYQFnoECB8QAQ&usg=AOvVaw0hXT58LZlUQNcn350xdVBv I tried uploading photos but they were all too big. I think the logic that the left pontoon didn't have the structure so the right pontoon doesn't need it holds. I also have a moke I'm rebuilding so know there's precious little structure anyway, the brackets to hold the cylindrical fuel tank in mine provided some structure. The battery boxes themselves could provide any missing structure in my opinion. What about under the rear subframe? There's a fair load of space under there for batteries with no spare wheel well. 1 Quote
fuzzy-hair-man Posted October 22 Posted October 22 I cropped some of my original photos of the subframe to get them small enough to upload. As you can see I've cut the sides out of the original subframe as the engine and box were wider than would fit. If you're able to move the gearbox further to the driver's side you might be able to keep the sides. Most / all car engine conversions I've seen require this much modification to the subframe. The rear of the gearbox sits about 10mm from the steering rack, the driveshaft allignment is pretty decent still a bit forward but I've seen much worse that still works. 3 Quote
Flash Posted October 23 Author Posted October 23 Thanks @fuzzy-hair-man, I really appreciate the time you have taken to crop your photos and drop them into this thread. It gives me a really good idea of the mods you needed to make. I also spent a bit of time looking at @Adoom's Mini build thread as he is using Nissan Micra engine/gearbox combo and had some photos of his subframe mods that I could reference. As you mentioned since I'm not using the NIssan engine and only have to deal with a small footprint electric motor I'm hoping that I can offset the gearbox more to the right and thus negate some of the sub frame cuts that you had to make. 1 Quote
fuzzy-hair-man Posted October 24 Posted October 24 Did you consider a Nissan Leaf gearbox / motor / inverter stack? The power figures are about the same. I can understand not going the Tesla SDU as the power is a bit ridiculous (but they seem to package well) but the Leaf seems a reasonable option? If set on the hyper9 is the Leaf gearbox an option? 2 Quote
