tortron Posted August 29 Posted August 29 Your carb fuel bowl has a float joggler (not air tight) and probably a small ventilation hole in the lid. So the system isn't vacuum tight. Sometimes fuel will leak out the bottom joiners (usually see some varnish underneath) 3 days to drain the system dry sounds normal? Manual prime pumps were a thing for that reason. My morrie will prime on the electric SU pump for a good few seconds if not been run the day or two before You could stick a vac gauge in the fuel line to check if you think.its that Quote
Flash Posted August 29 Author Posted August 29 2 minutes ago, tortron said: Your carb fuel bowl has a float joggler (not air tight) and probably a small ventilation hole in the lid. So the system isn't vacuum tight. Sometimes fuel will leak out the bottom joiners (usually see some varnish underneath) 3 days to drain the system dry sounds normal? Manual prime pumps were a thing for that reason. My morrie will prime on the electric SU pump for a good few seconds if not been run the day or two before You could stick a vac gauge in the fuel line to check if you think.its that Thanks heaps for your input @tortron Sounds like I may be chasing a fairy then. Perhaps I need to be looking at a prime pump. Quote
jakesae101 Posted August 29 Posted August 29 Su are very sensitive to pressure so if you change to an electric pump, use one of the glass bowl style filter regulators as they only need about 1.5psi 1 Quote
tortron Posted August 29 Posted August 29 Ypu might be able to fit a mechanical pump with primer lever. Some of the B series engines came with this setup (a pull ring). Im told the gaskets bolting pattern is the same between the A and B seri3s pumps. So maybe will work with the correct length pumping lever swapped in 1 Quote
Flash Posted August 29 Author Posted August 29 Thanks heaps for the additional info fellas. I'll do a bit more homework on this. Quote
Bearded Baldy Posted August 30 Posted August 30 We fit quite a few boat primer bulbs to vintage cars at work that spend most of the time sitting around. Few squeezes and away you go. 3 1 Quote
Flash Posted August 30 Author Posted August 30 That's a bloody good idea. Thanks for sharing. 1 Quote
Bearded Baldy Posted August 30 Posted August 30 No sweat. Have been used on everything from citroen 2cv' to 351 clevos and no fuel starvation issues. 1 Quote
Tiger Tamer Posted August 31 Posted August 31 If you are using an electric pump you could wire in a switch to prime the carb (I think you are without looking back) before you hit the start button. have done that before. Quote
Tiger Tamer Posted August 31 Posted August 31 6 minutes ago, Tiger Tamer said: If you are using an electric pump you could wire in a switch to prime the carb (I think you are without looking back) before you hit the start button. have done that before. Sorry. I looked back and you are using a mechanical pump. 1 Quote
Crispy Posted September 2 Posted September 2 Almost everyone I’ve talked to that used those KAD short shifters has quickly taken them out again. (Probably why yours was also not installed). The ball doesn’t seem to sit low enough in the cup and they reckon it pops out of gear and they can’t grab gears etc. YMMV and I haven’t tried one myself though. Quote
Flash Posted September 3 Author Posted September 3 Yep, I've heard similar things. They recon if there is any wear in the cup fitting the short shifter exacerbates the problem. Quote
Flash Posted October 13 Author Posted October 13 I'm so chuffed you asked Damo. NetGain Hyper9 IS brushless AC motor, AC-X1 controller, Elcon 600W DC to DC Converter and ZEVA EVMS3 Battery Management System. Motor will be directly coupled to a Toyota C52 gearbox which I will run without a clutch. Gear linkage will be modified to allow selection of 2nd and 3rd gears only. 2nd gear used around town and 3rd gear selected for open road cruising. Custom made billet driveshafts using Leyland outer CVs and Toyota inner CVs. 36 x brand new LiFePO4 Premium Grade A High Rate Traction Grade 100Ah cells connected in series and providing a nominal capacity of 115.2 volts DC peaking at 131.4 volts DC which is just under the controller's 132 volt DC envelope. Range is conservatively estimated at 75 km which is more than enough for my needs. 4 2 Quote
Willdat? Posted October 13 Posted October 13 19 minutes ago, Flash said: I'm so chuffed you asked Damo. NetGain Hyper9 IS brushless AC motor, AC-X1 controller, Elcon 600W DC to DC Converter and ZEVA EVMS3 Battery Management System. Motor will be directly coupled to a Toyota C52 gearbox which I will run without a clutch. Gear linkage will be modified to allow selection of 2nd and 3rd gears only. 2nd gear used around town and 3rd gear selected for open road cruising. Custom made billet driveshafts using Leyland outer CVs and Toyota inner CVs. 36 x brand new LiFePO4 Premium Grade A High Rate Traction Grade 100Ah cells connected in series and providing a nominal capacity of 115.2 volts DC peaking at 131.4 volts DC which is just under the controller's 132 volt DC envelope. Range is conservatively estimated at 75 km which is more than enough for my needs. I'm not sure if I shared these from when I was in the US? https://share.google/OyvGcab42AsVCthPq I can see ev/moke great combo, following with enthusiasm! 2 Quote
Flash Posted October 13 Author Posted October 13 Thanks for sharing @Willdat? That is insipiring. I may be wrong but from your photos I suspect that is a Chinese EV Moke manufactured by Chery Motors. I've heard they are pretty underwhelming with a top speed of around 45 km/h. Jaunt Motors in Melborne are commercially converting Mokes to EV using the same HyPer9 motor that I will be using. A trunkey EV Moke from them will set you back an eye watering $140,000. 2 1 Quote
dmulally Posted October 13 Posted October 13 What a setup! Will be like a rocket compared to what you have now. The hyper 9 is probably one of the best/popular motors out there but sounds like the rest is all set up. Looking forward to this one. Quote
Flash Posted October 13 Author Posted October 13 Thanks for the feedback Damo. Yep I'm looking forward to the journey too. What a steep learning curve I am on. Quote
dmulally Posted October 15 Posted October 15 Now that it has been revealed why the weight loss stuff is so vital, are there carbon fibre panels you can get that could help? Also I reckon it might be worth looking at ditching that gearbag. Shirley the torque of the Hyper 9 and the low weight of a moke can be overcome by final drive ratio selection. No idea how you'd get the wheels to actually turn but perhaps a small diff with the engine either in front (doubt there is space) or behind (doubt there is space unless you cut out the tunnel), or maybe mounted on top with a chain drive to a diff. Quote
