Adoom Posted August 14 Posted August 14 Where, preferably in 'the' Hutt or Masterton, could I get some 10mm aluminium plate? Two pieces, approximately 300X300mm. Needs to be a weldable alloy. I'm in the middle of making a fuel cell and I need a large access hole to mount pumps, surge tank/bucket and level sensor stuff. Quote
dmulally Posted August 14 Posted August 14 Lamberts Engineering in Masty will either have some on the rack or be able to get it in I'm sure. Quote
Adoom Posted August 14 Author Posted August 14 12 minutes ago, dmulally said: Lamberts Engineering in Masty will either have some on the rack or be able to get it in I'm sure. ...Masty... Are they a 'better have some cash on you', or will I be able to eftpos, place Quote
dmulally Posted August 14 Posted August 14 34 minutes ago, Adoom said: ...Masty... Are they a 'better have some cash on you', or will I be able to eftpos, place I would deffo bring cash. Try and speak to John if possible. If he isn't in you might be hard pressed to get what you need. Quote
Bling Posted August 14 Posted August 14 I got some round bar from Little Metals, if nothing local pops up. Was pretty quick service all those years ago I needed 70mm or something round bar. A quick look suggest they supply plate in 7075 T651 and 6061 T615. Quote
oldrx Posted August 14 Posted August 14 Altus sell 6061 offcuts https://altusindustrial.co.nz/aluminium-sheet-and-plate/off-cut-stock Quote
