deankdx Posted August 5 Posted August 5 3 hours ago, Bearded Baldy said: Psst psst put one in your luggage next visit westward. The dont charge the wank tax that people do here. at least single rails have a different shifter location (from 6cyl cortina which is closer to the bell housing by 100mm i'd guess) no overdrive though. shifter housing is usually sloppy like a stick in a bowl of mud. but when re bushed are very decent shifting. Quote
Bearded Baldy Posted August 5 Posted August 5 @deankdx i know he wont run a single rail in the jag, was laying groundwork so on his next trip over he brings me a spare bahaha. Sorry for the spam @dmulally, late model ute 6 speeds are poos for ratios, you would be shifting gears like a roadranger. They are also all relatively chonky too. Aside from shifter being a bit far back, old mitsi km132s could hold up to turbo starions and whatnot, and you aren't as rough a driver as most 18year olds who used to have them. 1 1 Quote
dmulally Posted August 5 Author Posted August 5 8 hours ago, Bearded Baldy said: @deankdx i know he wont run a single rail in the jag, was laying groundwork so on his next trip over he brings me a spare bahaha. Sorry for the spam @dmulally, late model ute 6 speeds are poos for ratios, you would be shifting gears like a roadranger. They are also all relatively chonky too. Aside from shifter being a bit far back, old mitsi km132s could hold up to turbo starions and whatnot, and you aren't as rough a driver as most 18year olds who used to have them. Chur. I was hanging out for a gearbox with a bolt on bellhousing because that is what my engineer said but if I cant get one then an integrated one will have to do and just get sliced. I posted the isuzu one as although it is a 6 speed, 6th is double overdrive. But I assume you'd never use first. I was boring @chrisR last night about the Commer having a Lexus 6 speed box and with the pissy torque from a 1725cc, it needed a gear between 2nd and 3rd. Annoying. If I could have a 3 speed manual and a bucket of torque I would. Im laaaaaazy but not automatic lazy. 1 Quote
BiTurbo228 Posted August 6 Posted August 6 If the Isuzu box has a double overdrive 6th you could just keep the shorter diff and treat it like a dogleg 5-speed with an extra crawler gear for creeping traffic (or towing, if you're into that). Could be the only S-Type in the world that's capable of pulling a tree stump out What are the ratios and I can work it out for you. 2 1 Quote
Popular Post dmulally Posted August 6 Author Popular Post Posted August 6 Well I went to measure the cd009 gearbox and before you knew it I traded my old quad bike for the box, mechanical speedo cable adapter, and a whole new set of different diesel ratios. Means I have to cut the tunnel but by my man maths the shifter "should" clear the seats. Also swapped an old evinrude 15hp for a 1939 Johnson Seahorse. 6 1 6 Quote
dmulally Posted August 20 Author Posted August 20 Pro's Wider engine bay and tunnel Bigger radiator Luxobargey waftiness Con's Would have to sell the s-type thus dealing with Jag Barry's Seats would need retrimming 400kgs heavier so not as sporty 9 Quote
Thousand Dollar Supercar Posted August 20 Posted August 20 That's a proper villainous Jag. 400kg is a massive weight difference though. Also, here's another kind of 420 G. Ooh wee, put it in the air! 🚬😶🌫️ 7 Quote
BiTurbo228 Posted August 20 Posted August 20 ...that 1300hp would sort out the 400kg weight increase quite nicely Ok, let's be sensible. 900hp then... Quote
dmulally Posted August 20 Author Posted August 20 7 hours ago, Thousand Dollar Supercar said: That's a proper villainous Jag. 400kg is a massive weight difference though. Also, here's another kind of 420 G. Ooh wee, put it in the air! 🚬😶🌫️ An AJ6 would be rattling around in there. Looks like it deserves a V12 or LS. 1 Quote
dmulally Posted August 20 Author Posted August 20 Hard to find a size comparison between the two so the best I could find was a 420g and 420 taken at a pointless angle. Plus other random cars for a laugh. 5 Quote
igor Posted August 21 Posted August 21 13 hours ago, dmulally said: An AJ6 would be rattling around in there. Looks like it deserves a twin turbo V12 Fixed it for you. 1 Quote
Popular Post dmulally Posted August 23 Author Popular Post Posted August 23 Can I say something without everybody getting mad? 7 5 3 Quote
CUL8R Posted August 23 Posted August 23 Thats a proper badass Jag well done on the purchase 1 2 Quote
Goat Posted August 23 Posted August 23 Ho-lee. Arent they like 6ft wide or something! Looks super badass in black. Is the paint as good as it looks? Will you sell the tipple carbs? I'd be keen 2 Quote
Goat Posted August 23 Posted August 23 Saw your S-type on facebook. Good luck with the sale. Hope you don't get mucked around 1 Quote
Goat Posted August 23 Posted August 23 Also, if you're still on the hunt for an AJ6 engine, I'm looking for an XJ40 rear end. (Outboard disc hubs and driveshafts to convert my s1 to outboard disc) I would be keen to go in on a parts car with you if you'd be interested, or vice versa. Can have a stripping party (and can also pull the car to bits and send the rest to scrap) 4 2 Quote
dmulally Posted August 23 Author Posted August 23 17 minutes ago, Goat said: Also, if you're still on the hunt for an AJ6 engine, I'm looking for an XJ40 rear end. (Outboard disc hubs and driveshafts to convert my s1 to outboard disc) I would be keen to go in on a parts car with you if you'd be interested, or vice versa. Can have a stripping party (and can also pull the car to bits and send the rest to scrap) I'll send you dick pics/flirty pm. 2 Quote
