d.p.n.s Posted June 26 Posted June 26 So from my understanding there may be a few toyotas that use the same driveshafts (bolt pattern wise) Im currently using a cressida rx60 drive shaft in my mk3 cortina with a w50. The front section is perfect fit but the rear section is a little short so im using a spacer I made My rear section is 750mm and im looking for something around 770mm - 785mm Pics of dimensions of mine below Anyone know of what makes models use the same bolt patter . Thanks in advance Quote
smokin'joe Posted June 26 Posted June 26 Pick-a-part and hunt out solid rear/4wd Toyotas.early caribs/townace/liteace etc will have a nosy downstairs, but suspect mine are the short ones 1 Quote
d.p.n.s Posted June 26 Author Posted June 26 18 minutes ago, smokin'joe said: Pick-a-part and hunt out solid rear/4wd Toyotas.early caribs/townace/liteace etc will have a nosy downstairs, but suspect mine are the short ones Appreciate it , Do you know if there's a list somewhere ..someone made of the years? Quote
smokin'joe Posted June 28 Posted June 28 On 27/06/2026 at 10:38, d.p.n.s said: Appreciate it , Do you know if there's a list somewhere ..someone made of the years? Toycrazy ??? @ae25 may have been involved and there was photos measurement of many conversion parts 1 Quote
Bling Posted July 2 Posted July 2 https://www.toycrazy.net/index1.html Not sure if Mark did driveshaft comparisons. If anyone has though, it will be him, so check the site. @AE25 1 Quote
ajg193 Posted July 6 Posted July 6 Hijack time. Starlet driveshaft has done 43 years now with never being greased. No signs of problems yet. They have no grease nipples from factory. Is it worth trying to disassemble and regrease or best just to use it until it fails? 2 Quote
Bearded Baldy Posted July 6 Posted July 6 Full send until it needs new ones. Which it never will. If you try to disassemble it, you may as well fit new ones while there. They are cheap enough. Or risk dropping one roller off the bench never to be seen again. 1 Quote
Roman Posted July 6 Posted July 6 8 hours ago, ajg193 said: Hijack time. Starlet driveshaft has done 43 years now with never being greased. No signs of problems yet. They have no grease nipples from factory. Is it worth trying to disassemble and regrease or best just to use it until it fails? I think its only a problem if the driveshaft comes within 2 feet of the ground 2 5 Quote
