~Slideways~ Posted July 13 Author Posted July 13 The clock wasn't working, I got another from Pick a Part. It also wasn't working. Took it apart and found cracked solders on these: Added a bit of new solder and all working again. Also fitted a few bulbs to the gauge cluster, it's still a bit dim so I might see if there are any bright LED options. 4 Quote
~Slideways~ Posted Tuesday at 23:16 Author Posted Tuesday at 23:16 Been driving this everyday, have put a couple of thousand km's on it. Best fuel economy I got out of it was 9.7km/l which is not bad for what it is, especially since that was all commuting, stop go traffic and some spirited driving. Found a bit of rust to deal with in the rear quarter, have a few months before wof is due to fix it. Also found a 20mm rear sway bar, to upgrade the 17mm one. Have tidied it up and painted. Hurt my back a while ago so haven't fitted it yet, will be interesting to see the difference. I get a bit of tire rub in the rear cornering hardish so might help with that. 5 Quote
