~Slideways~ Posted June 14 Author Posted June 14 All of the internets told me that early versions of TGV's like this work by staying closed for the first 30sec of warm up then open. But having them visible like this shows that they stay closed until the first throttle input. I left it idling for over a minute and they stayed closed until I touch the throttle. Here is a video, filmed in the dark with a torch, through the dirty windscreen zoomed in through the bonnet gap lol... 3 Quote
mjrstar Posted June 15 Posted June 15 I understand there is a cheap (read only) cable and an expensive (genuine) read and write cable. I believe I probably still have one of each in my stash from my evo road tuning days if you'd like to borrow them to trial? 1 Quote
~Slideways~ Posted June 15 Author Posted June 15 15 minutes ago, mjrstar said: I understand there is a cheap (read only) cable and an expensive (genuine) read and write cable. I believe I probably still have one of each in my stash from my evo road tuning days if you'd like to borrow them to trial? From what I've found, these clone Tactrix version 2.0's (at least the current ones) work fine for later 32bit ecu's (around 2006 onwards) but not for the 16bit ecu's like mine. The genuine 2.0 might work, my best bet is an earlier version 1.3 cable apparently. Awesome of you to offer, what version do you have? I've got another contact who has one, not sure what version or if genuine but he's local so I'll try that first. I got these TGV bits for $30 locally so it made sense to try get it up and running with these after having issues with the cable. I wonder why Tactrix seems to be awol? They promised a new version 3.0 but seem to have all but gone out of business. Possibly the EPA crack down in the US? Quote
mjrstar Posted June 15 Posted June 15 I'm pretty sure it came from these guys many moons ago. I can't be certain it's a 1.3 but it worked fine flashing the evo 7 ecus I was working with at the time. https://evoscan.com/product/openport-1-3u-universal-usb-datalogging-and-ecu-reflash-tuning-cable/ Quote
~Slideways~ Posted June 15 Author Posted June 15 31 minutes ago, mjrstar said: I'm pretty sure it came from these guys many moons ago. I can't be certain it's a 1.3 but it worked fine flashing the evo 7 ecus I was working with at the time. https://evoscan.com/product/openport-1-3u-universal-usb-datalogging-and-ecu-reflash-tuning-cable/ That sounds perfect if its the 1.3! Quote
yoeddynz Posted June 15 Posted June 15 How stand alone are these stock ecus? Is the cars system easy enough to bypass so you can run an aftermarket ecu? Quote
~Slideways~ Posted June 15 Author Posted June 15 12 minutes ago, yoeddynz said: How stand alone are these stock ecus? Is the cars system easy enough to bypass so you can run an aftermarket ecu? Good question, but I reckon probably pretty simple no canbus or anything in these. Looks like there is a plug in Link ecu too. No money for that with this car though. Should be good on factory stuff though, just need to sort these last few issues. 1 Quote
Raizer Posted June 15 Posted June 15 Rock Auto adds GST at checkout. $20 clone Openport 2.0 direct from Aliexpress reads and writes fine on both my 08 and @chris r's 06 Germans. /You're almost making me almost miss my Subaru days ha! 1 Quote
~Slideways~ Posted June 15 Author Posted June 15 1 hour ago, Raizer said: Rock Auto adds GST at checkout. $20 clone Openport 2.0 direct from Aliexpress reads and writes fine on both my 08 and @chris r's 06 Germans. /You're almost making me almost miss my Subaru days ha! Yeah thats pretty much the case it seems, they work for everything except early 2000's subaru 16bit ecu's (yay for me lol). Lots of Google results with people saying the same, even an HP Academy article saying 16bit subaru ecus are difficult. Unfortunately I cant just swap to a 32bit ecu. Quote
~Slideways~ Posted June 16 Author Posted June 16 Got the drivers side cam position sensor out, was pretty dirty but don't think that was an issue. Ohms reading is within spec: The wiring looks to be the likely culprit though. 1. The wires are both cracked at this plug: It still has continuity through to the cam sensor connector though, but from what I understand continuity doesn't necessarily mean it's ok. Next problem is the sensor connector itself is brittle and the retaining clip inside has snapped off and the wire easily slides out. Whether this wasn't touching the pin before or it happen when taking it out this time I don't know. Wire pulled out: You can see the broken inside clip that is meant to retain the pin on the top hole here: So I've cleaned up the sensor, reinstalled and searched for replacement connectors. Turns out it is a standard Nippon Denso plug mostly used for injectors, but it has to have the low keyway. MSEL had some so have ordered 2, the other side is probably ok since it isn't near the turbo heat. So hopefully this solves the limp mode. 8 Quote
~Slideways~ Posted June 20 Author Posted June 20 New plug arrived and matches: Properly crimped new pins onto some new wire to replace the crunchy section: Installed with conduit and heat shield tape since its near the turbo: Started it up and checked codes, no longer getting a Cam Sensor code, win! Still has the idle and o2 sensor, code though. I was hoping idle code could be linked to bad cam sensor signal. Test drove it and no longer rev cutting at 5k but still seems to be limiting boost and quite sluggish, so is it still limp mode without a rev cut? I have ordered a Denso o2 sensor from Rockauto, should arrive in a week. To make it worth it for shipping i bought a bunch of oil filters for a few cars. I also tried a few more things that the internet told me might make the Tactrix cable read the ecu. Including jumping 12v to the 'flash block' plug. But made no difference. So that means at least for now in order to drive it I need to have these 'dummy' TGV's wired in. So I used some conduit and extra plugs in order to run the cables neatly through the engine bay then through the fire wall. Now I'll have the dummy TGV's under the driver's seat. Its actually surprisingly neat for a temporary workaround. Here it is in the driver's footwell, and the wires are long enough to tuck under the seat. Weird I know, but it works for now. Engine bay, cant tell there is extra wiring anymore. 6 1 Quote
~Slideways~ Posted June 20 Author Posted June 20 Its possible the idle control is just gunked up, so I'll get a o'ring gasket (funny shape that never goes back in) from Subaru then take it off and see what it looks like inside. 2 Quote
~Slideways~ Posted June 23 Author Posted June 23 Gah bugger it, Subaru has no stock on that IACV gasket and is a month wait from Japan. So I might as well order it from Amayama again for 1/5th the price. In other news the o2 sensor arrived yesterday so will get that installed as soon as I have time, then see how it runs. 6 Quote
~Slideways~ Posted July 2 Author Posted July 2 Have since discovered that the idle control valve is dead, resistance test shows OL between pin 2-3. 1-2 is too high as well. There are 'cheap' aftermarket IACV's available but most say they are crap so trying to find a good 2nd hand one. This style IACV was only used on the 2002-2005 turbo wrx's and a few early 2000's turbo models Foresters and Legacy's. Nothing at Pick a Part Wellington, all N/A engines there except one which is the wrong kind. I've checked all PaP listings around the country and nothing. Contacted some local wreckers and no replies, most likely they'd only keep good engines and won't want to separate. Where did all of these go?! Found a guy with one but have not heard back for a few days. Frustrating since it's so close to being ready to drive! Quote
Popular Post ~Slideways~ Posted July 7 Author Popular Post Posted July 7 Success, I found a couple of 2nd hand genuine idle control valves but they didn't really make any difference. So since I had a spare I completely disassembled it and found that the shaft was stuck even after being soaked in various things. I got it moving nicely and reassembled, it is adjustable with oval holes on the motor/coil part, like some TPS's so I got it as close as I could. Now it idles and has no code for the IACV. Win! So now the oxygen sensor and iacv codes are solved. I've been driving it a bit and there is still a cam sensor code coming flashing the check engine. It runs totally fine and keeps getting better, from what I under stand the ECU gradually increases the ign timing and boost control based on knock and o2 sensor (after the ecu is reset). It's now up to 14.5psi exactly. I swapped in an old Gizzmo boost controller with a digital display just to use as an accurate boost reading. Threw the old boost gauge in the bin. One of these: It's definitely well geared for fun driving, probably not so much economy. Pretty certain it's the 4.4 final drive version based on the code on the gearbox and chassis plate. It also does just under 3k rpm at 100kph. So this cam sensor check engine flash, I'll have a look at the other sensors but for now it seems to be running really well. 12 Quote
mjrstar Posted July 8 Posted July 8 I had one of those ibc's in my evo and it was faultless. However same type of unit in my mx5 is up to no good. Man I hate electrical items that don't just work. 3 Quote
~Slideways~ Posted Monday at 01:03 Author Posted Monday at 01:03 I've been driving this despite the cam sensor error, the engine check light for the 2 cam sensor codes are: P0340 and P0365 Interestingly the check engine light only stays on at low rpm, and there is an exact rpm where it turns on or off, but it changes that point each time (may be heat related), while always being under 2000rpm. So it seems fine under most driving conditions. For example as soon as you start the engine, it has the check engine light and it turns off at around 1800rpm then back on as soon as it drops below that. So while driving it is almost always off until you are idling or even between gearshifts if you let the rpm's drop that low. There are 2 cam sensors which are located on the back of each head at the top and another sensor on the passenger side behind the top cam gear. I have tried: - cleaning all three sensors. - testing ohms readings: the 2 main ones are around 1950ohms (identical) and I can't remember what the third one was (the cam gear one). But all within spec. - replaced split wiring and connector on the drivers side one (I thought this solved it originally but it came back). - passenger side wiring looked fine. - cleaned all loom plugs and pins. - the alternator is noisey but still good voltage. Tried removing the belt to just run off battery but no change to the check engine light. - one internet theory was bad grounding on this gen wrx. So I added three thick ground cables, but made no difference. Some possibly reasons according to google: - Alternator amp's could explain it going away with slightly higher rpms (but removing drive belt kind of defeats this theory). - one guy with a oscilloscope found noise being generated so directly soldered extra grounds to the ecu pcb itself. I could just buy 3 new sensors, at around $100 each. But heaps of reports that this didn't solve the problem for other people and it seems weirdly unsolvable? I decided to take it for a reasonably spirited drive through Ohariu Valley > Takarau Gorge > Karori, it goes very well for basically stock. I don't know what the stock heavy flywheel would have been like but this light one makes it really fun to rev match and quick down shifts etc. Absolutely no problem in heavy traffic like some internet people suggested. Some things I'd like to change soon: - Remove old alarm system (20-25 years old, randomly going off and only one remote) and probably install something else. - Seems pretty understeery, so want to try change the rear sway bar (only 17mm on wagon, but 20mm on some sedans of same gen) - Most speakers are buggered. - Tyres that came on the BBS wheels are almost full tread but are definitely not performance tyres, ok in the dry but first wet roundabout felt like it just wanted to understeer. Just managed to catch the Sun going down: I put in it's first full tank of 98, will be interesting to see what the fuel consumption is like. Maybe I'm kidding myself but with the brand new o2 sensor, maybe it'll be decent? 8 Quote
yoeddynz Posted Monday at 01:54 Posted Monday at 01:54 Looks really nice in that pic. There's almost a modern 911 vibe going on with the front end. 3000 at 100kph seems pretty normal for the type of car? - certainly not low geared imo. 1 Quote
~Slideways~ Posted Monday at 02:33 Author Posted Monday at 02:33 39 minutes ago, yoeddynz said: Looks really nice in that pic. There's almost a modern 911 vibe going on with the front end. 3000 at 100kph seems pretty normal for the type of car? - certainly not low geared imo. I'm not sure what they were going for with the round lights, maybe copying Toyota? Same car: Re rpm's the US V7 WRX's are usually 3.9:1 and 2400rpm @ 60mph so I reckon it'd be quite different to drive. Quote
~Slideways~ Posted Monday at 02:47 Author Posted Monday at 02:47 Another thing I've noticed is the front grill surround is quite different and looks much better than the samples below where it is more flat. While on mine is extends out much more: Quote
