Shifter was super floppy so I installed a new linkage jobby thing:
I did not change the other bushings here,it feels like new now though. Maybe later I'll do the other bushes but I think I fixed the main issue.
  • Replies 101
Engine mount has these heat shields, I'm missing one, not sure if I lost it while taking the engine out or if it wasn't there when I got it.
I made this out of some scrap. Not pretty but it'll do.
Another USDM vs JDM comparison that I forgot in that earlier post:
Compression ratios.
USDM: 8.0:1
JDM: 9.0:1
That's a pretty significant difference, I assume it's because Japan has access to better fuel than some of the US market?
Should make for better economy, better response etc etc.
On 08/05/2026 at 13:46, ~Slideways~ said:
@azzurro
Thanks for the scope creep.
... All 3 were very clean so I am not worried about the 4th one...
Your welcome! Good sign the engine has regular oil changes.
Looks like you dont need any help with scope creep tho!
Giz link for aliexpress leather knob? Mine has holes in it and i hate it
The front inner cv boot was ripped.
I managed to replace it by removing the knuckle which is enough to pull the CV apart at the gearbox while leaving it still attached at the gbox.
Cleaned it out, replaced grease and boot with a genuine kit:
Those clamps are great, what a good design, reusable and don't need any fancy tools.
Didn't take any photos after this because I was covered in grease.
Tried the new wheels on. Monster truck wheel gap lol.
I've since had it on the ground again and it is at a nice ride height and the offset looks pretty much perfect.
  • Like 9
Discovered the turbo is an TD04HL which only seems to have come on some JDM versions of the WRX and maybe Forester, it's higher flowing version than the TD04 and TD04L which was normal on the USDM and earlier model jdm WRX's.
The TD04L is the most common and very fast spool but no top end.
TD04HL is more for mid and top end giving up a small amount of spool time.
Interesting numbers I found
Inducer sizes:
1) TD04L ..... 46.8 x 41.2mm 7.7mm tip width .
2) TD04 std ... 47.2 x 40.0mm 6.8mm tip .
3) TD04H ...... 52.0 x 44.0mm 7.7mm tip .
4) TD04HL ..... 52.0 x 45.6mm 8.9mm tip .
The compressor sizes:
13T-6 ... 40.64 x 56.0 4.98 tip . 52.6 trim .
15T ...... 42.00 x 56.0 5.38 tip . 56.2 trim .
16T ...... 43.40 x 56.0 5.70 tip . 60.0 trim .
It seems most likely it is a 15T.
So based on the fact that a USDM car of the same year only had 8.0:1 compression, smaller port head, no AVCS, and 3.9:1 final drive, they get the smaller TD04L probably in order to keep response.
And JDM get 9:0.1, big port heads, AVCS (helps turbo spool and bottom end), 4.4 final drive and the higher flowing TD04HL.
Man the US got wrecked.
Put the intake back together with new gaskets:
You can see here that the top part of the intake manifold could have actually been ported out a bit but I'll leave it.
Making use of the tiny torque wrench I bought a while ago for really low Nm stuff:
Only goes up to 25Nm or so, but really handy:
Replaced the 3 fuel lines under the intake manifold which are known to leak with age, really hard to do without taking the manifold off so cheap insurance. I was going to replace with some ethanol safe fuel hose I had left over but the Subaru stuff is smaller than the 8mm ID I had so just bought genuine since it was cheap enough.
