  • Replies 49
Initial look over it at home.
The good:
5 speed and I think it might be the good 4.4 ratio.
Recent wof.
It has the nicer black headlights, never liked the bug eye's really but the STI type lights look much better. Need a polish or clear coat.
Pretty sure it has an LSD in the back.
Underneath is really straight and rust free.
Still has the cat's in uppipe (bad) and big one in down pipe. So semi un-modified.
King springs of some sort.
Alloy bonnet.
Twin wing and '20k' body kit stuff.
Decent Sony bluetooth head unit and an old rockford fosgate sub amp and wiring. (speakers iffy).
The bad:
Drivers window doesn't work.
Heatcore bypassed. I missed this...bugger.
Bit of rust at the back, nothing major.
Interior very dirty.
Drivers seat stuck.
Some bad paint colour match.
Clutch is very bad, but priced accordingly.
High high km's.
Wheels have to go.
Spent about 3 hours with a carpet cleaner, on seats, mats etc.
Cleaning spray and wipes on all surfaces.
Came up really good. Drivers seat needs some bolster foam and stitching though.
Oh and I forgot to mention the gearshifter is super floppy but I knew that would be bushes.
Decided clutch would be best to take the engine out, but before that I'll do a compression test.
While cold it came up 150psi on all four within a few psi, the amazing thing is it's done 311,000kms 😅
Happy with that!
  • Like 9
I wonder if the shudder in first, down on power and rough idle is a misfire? My last legacy was missing a complete cylinder (bad coil) and other than being down on power and a wobbly idle you could barely tell it was misfiring. it still drove fine and was surprisingly smooth otherwise.
I will have to check coils, good idea.
Jumping ahead a bit but:
I've found a couple of possible explanations for the shudder.
1. The clutch friction disc was almost on the rivets.
2. The Flywheel has heaps of micro cracks.
3. The clutch fork contact lobes were worn almost completely flat.
It's probably 3, but it could also just be a high k's gbox?
For the low boost pressure, I am pretty certain it will be because it has had the vacuum hoses replaced and is missing the 'boost pill' air restrictor.
It may have been getting an easy life for years only running 8-9psi. I originally thought it was 7psi but realised the cheap boost gauge didn't return to zero, more like -1.5psi
My first thought was a gunked up boost solenoid but then I found no boost restrictor at all.
I'll know once the car is back together.
Spot the vent to atmosphere BOV, probably a big part of the drop in idle wanting to stall.
But otherwise a pretty stock engine bay. Which is a good sign.
Something weird going on with that intake pipe from the air box, took it out and found this bodge:
Less of a good sign...
Reasonably modern coil on plug:
Plug look pretty old, at least they are platinum but the electrodes are worn.
First indicator of rock hard cracking rubber, thought maybe a cause for boost control issue but this will be on the bled off side:
Time for the engine to come out:
Engine has AVCS and TGV's.
Noted that these head castings indicate that it is a big port head, I did not know that was a thing, never had a Subaru.
The internet tells me this is likely the same as the STI heads of the same generation (probably different cams though and block is open deck).
Clutch off, very worn but maybe not quite on the rivets yet.
Unfortunately then found the flywheel has had a hard life! I asked the machinist and he said he could try machine it but doesn't think they will all come out.
I had read that this was the generation where they added a catalytic converter to the uppipe, before the turbo. Apparently these fail, break up and go through the turbo.
So I removed the uppipe and can see a cat and it is separating from the outer part. I can literally push it in and out.
So I found an aftermarket up-pipe on FB market place:
No cat:
I originally refitted the EGT sensor which is only really there to check for a blocked cat, but I realised it doesn't seat properly. So I removed it again.
Here you can see that the original uppipe inner diameter is quite small too. About 42mm.
New one is much bigger at 52ish.
From what I read, the removal of the pre turbo cat makes a big difference to turbo response and Subaru only did it for about 4 years then removed it.
The bigger diameter is good in theory but pre turbo it might actually slow gas flow down. But it is what it is.
I tried to swap the studs over but a couple refused to come out even with heat:
I cleaned up the threads in the 'new' up pipe flange and bought some fancy new studs and nuts from Sinco.
By this time I was making a list of parts I needed, one was the oil separator plate behind the flywheel. These used to be plastic and known to crack, there is a recommended stamped steel version you can buy new during a clutch job.
Luckily mine has the thick aluminum one so not a problem, I don't think they make these anymore only the cheaper stamped steel version.
So I needed to solve the flywheel problem, this quick clutch job to get it back on the road was turning into a much bigger list of things to do.
I priced up a genuine flywheel, that was going to be almost $1k through Amayama.
So I decided to try a light weight chromoly flywheel. I did a bit of research and some (mostly American) opinons are that it can cause some issues. Like stop go traffic and some even say timing issues. Others love it.
But I did it anyway. I'm hoping it'll make it more rev happy and fun to change gears etc. Guess I'll see.
I also bought an slightly uprated clutch, about 15% more clamping force. The friction disc is also bigger diameter.
I then discovered that the clutch fork was very worn, possibly explaining the bad condition of the flywheel and clutch.
This is what prompted me to check (I hadn't removed the fork yet).
So I ordered a box of bits from the local subaru, the prices weren't great but I really wanted to get it back on the road and not have to wait for Amayama shipping (spoiler alert, I ended having to order more stuff anyway).
Brand new genuine subaru fork, last one in the country apparently.
  • Like 8
In that box of Subaru genuine stuff was
- cam cover gasket set (including bolt washer seals)
- intake manifold gaskets
- clutch fork
- water cross over pipe o-rings
- front inner cv boot kit
- rear main seal
- oil filter
- air filter
- 3 x water hoses (crunchy)
- sump oil return o-ring
- oil pick up o-ring
Oh how naive I was with Subaru stuff thinking this would be all I'd need.
  • Like 8
Rear main seal job.
3d printed this tool to help press the new one in the correct depth.
Old one out:
New one in, as you can see someone has previously been a bit rough with a hammer but it's only on the face so doesn't matter.
Also spent quite a long time cleaning everything here.
  • Like 9
Not particularly a Subaru person but always good to see an oldish car getting a good going through. Looks like you’ve arrived just in time to save it.
High miles and still ok condition usually means that someone in ownership trail was good about maintenance, probably the same person who added most of the miles.  High miles also tend to be long distance miles, so reasonably low hours.
Keep up the good work 🙂
