Tumeke Posted May 1 Posted May 1 1 minute ago, felixx said: So I guess a stator and 'starting loom' off a Lifan will be whats needed with a CDI, Guess that is converting the Cub to 12v as well I have a couply dead 90cc lifans hiding somewhere, could scrounge em off them? I think the only thing that needs a bit of fab is making sure the pickup fits in the case You use the stator base, stator, flywheel and wiring. It's been a while since i've done one and had way too many bikes in between to be sure Prob just check the crank taper is the same for the flywheel. 1 Quote
felixx Posted May 6 Author Posted May 6 So I have some bits, side covers, new tyres, tubes brakes for her. New rear brakes, tyre and tube fitted. Front end will be done tomorrow or tonight She ran like shite, gave her a good thrash around the block and she idles much smoother. Im quite happy with her tbh Headlight and tail light bulbs ordered. I need to fit a battery before I put bulbs in.. its why the og ones blew lol 4 Quote
felixx Posted May 7 Author Posted May 7 19 hours ago, Bearded Baldy said: New parts? It is only original once you know! This is true, but I want to ride her, I have a deal with a fella if I can get some Repro legshields etc he will swap his OG Ones with me (He is doing a full resto on a cub) But ATM Leg sheilds are like rocking horse wheels 2 Quote
Bearded Baldy Posted May 7 Posted May 7 Incase it was unclear, i was taking the piss, i am a firm believer in build it how you want to, not for anyone else. 2 Quote
felixx Posted May 7 Author Posted May 7 14 minutes ago, Bearded Baldy said: Incase it was unclear, i was taking the piss, i am a firm believer in build it how you want to, not for anyone else. I know you were, but I want to keep her looking OG as but at the same time safe and reliable "Survivor Spec" 2 Quote
felixx Posted May 12 Author Posted May 12 So I jammed a new 6v battery in and indicators and horn began working. 6v bulbs arrived today. I bunged em in and fired her up. Gave her a little throttle and pop, no lights. I replaced em with a 12v led tail light and 12v incandescent headlight. Went for a thrash and the low beam filament blew but not the high beam I reckon the rectifier is shot. Any of you got an idea of what 6v rectifier to replace the selenium one with?? Quote
Raizer Posted May 12 Posted May 12 Remember when I said to fit a ballast resistor to your monkey to stop it popping bulbs? Same thing with this. Or if it's real old Quote
felixx Posted May 12 Author Posted May 12 I saw there was a wee thing that looks like a fuse holder under the battery retainer with nothing in it. Does this go inline with the battery? Quote
Raizer Posted May 12 Posted May 12 32 minutes ago, felixx said: I saw there was a wee thing that looks like a fuse holder under the battery retainer with nothing in it. Does this go inline with the battery? The ballast goes anywhere on the AC power wire from the engine/to the lights, all it does is dump excess power to ground to protect bulbs etc. Changing the selenium rectifier should make zero difference to most of the bulbs popping, all it does is crudely convert AC to DC and it's on a separate circuit to the head and tail lights. 2 Quote
Tumeke Posted May 14 Posted May 14 Do you want to fix it the right way or the easy way? I'd suggest the easy way. Throw some 12v bulbs up it and give it a rev and check what the voltage is. Try different combos - 6V front 12v rear etc and play with the wattages. I have 1 old 2t with a 24v rear and a 12v front. As long as it isn't popping bulbs you're golden. Pic for fred of the better cub. 6 Quote
felixx Posted May 27 Author Posted May 27 Well I got a resistor similar to what you showed me @Raizer I will plumb it in series with the headlight I guess. I have neglected this beast due to scooter safari, but it started 1st kick last night. I will do a 10km ride on it tonight then ride it to work tommorow Its currently getting 55kmh on the flat Brake light is not working. I have a new switch somehere Tail light is fine Does anyone have a c50 leg shield for sale 1 Quote
felixx Posted June 2 Author Posted June 2 she was stalling a lot at the lights, hard to start when warm, I have been told (by Barry at the petrol station)this is either a buggered condensor or the coil has a crack in it? I did some google foo and it could have been my valve clearences were too tight, this made them not close fully. As I have tools (but no condensor points or coil to replace) I adjusted them valves up to the looser end of the scale and it kinda helped, Idling is more even and it idles for longer without stalling. There is no tappet noise so I am happy for now However she is still hard to start at times, I do wonder if the rings are tired, although she does get up to 60kmh with no smoke Next up is ordering points, coil and condensor as I bet these are original, the tyres and tubes were. I do think the clutch is a bit stuck as sometimes she lurches when I put her into 1st then stalls and now and then she doesnt find 3rd (false neutral) when changing up, or 2nd when changing down (I have adjusted the clutch but it only helped a bit) Still looking for a leg shield and a rear rack, or else I will make a rack for her BUT I bit the bullet and rode her to School today 3 Quote
felixx Posted June 4 Author Posted June 4 So last night I went for a night ride I realised the previous owner must have used a wiper switch for the headlight. The light was intermittent as fuck (i never noticed this in daylight) I ripped it down and noticed sparks coming from a jiggly earth wire on the bulb holder. I told the bike I was disgusted and went to bed. Tonight I did lots 1) fix jiggly wire. No sparks 2) test voltage at bulb, 6v bike, 12V at idle, 30V when at 'annoy neighbour revs' 3) fit 25ohm resistor (@raizer)in series with headlight circuit.. still getting 24V 4) have a beer and a think 5) jeremy suggested earth issue so I made a piggy back to earth to frame. Now Im getting 2.4V at medium RPM 6) Call Moray (@mo99) He got me doing wizzy things with multimeter and looking at wires Suggestion is charging coil is chooched I have a parts motor I will pull one off and give it a hoon. Pray for me, this is all new for this fella 4 Quote
felixx Posted June 10 Author Posted June 10 Got an OG leg shield for this old girl, it had some cracks,I welded them up withmy temu plastic welder thingy.. still lookin for a rear rack 4 Quote
felixx Posted June 15 Author Posted June 15 So last week I tried to play auto electrician and it worked for a bit then didnt, then @mo999 gave me a hand and when he left all was working. When I tried poking the battery in I musta popped a coupla wires and plugged it all in again then nothing worked. Somehow I had AC entering the battery and chooched it so had have no horn or indicators. Fast fwd to today and a 6-24v led bulb came from China. Jammed it in and happy days! 2 Quote
Popular Post felixx Posted June 30 Author Popular Post Posted June 30 (edited) Well I have been riding her daily to work and shops and stuff and she is going great guns Lights still work, as does the horn and indicators, however the wee wire bit that clips into the brake light switch has broken so I need to source one of those ASAP I got a rack of @Hunterkiwi01 (on loan) and mounted a crate which really helps with shopping duties It has had an oil change and is about 300km into that. I will do another in 200km or so just to flush it. (it gets up to 63km/h or so on a good day which is good) The more I ride it, the better it goes, however it does have a wee stumble at low revs (Taking off at lights) so I guess its time to pull the jets and give em a clean. It has stopped stalling at the lights though (even on these cold mornings). It does appear to have a bit of a 'shimmy' or 'wobble' at 20km/h so I will investigate this further. Overall stock cub life, although slow is very chill. Edited June 30 by felixx Forgot to add a pft 11 Quote
