felixx Posted April 21 Posted April 21 So I got this. Was gonna fix her up for a mate, but he decided it was gonna cost too much. Made him an offer and now its mine. Sold my suzuki F50 and brought this pile. Comment away 6 Quote
felixx Posted April 21 Author Posted April 21 Plan is simple. 1 See if 49cc runs 2 replace tires tubes brakes, bulbs Send it 3 source some 2nd hand plastics, tidy seat, 8 Quote
felixx Posted April 21 Author Posted April 21 4) if number 1) Fails... Jam a 160cc in it and rip into the sunset on one wheel 3 Quote
Popular Post Willdat? Posted April 21 Popular Post Posted April 21 Cubs are a great resto project, mine hadn't run in 30+ years, a month or so later with overnight parts from Thailand it was purring. 14 Quote
Popular Post felixx Posted April 21 Author Popular Post Posted April 21 Carb was flooding. Tore it down and found this... Will hopefully get a replacement tonight 10 Quote
felixx Posted April 25 Author Posted April 25 Hanging out wuth @Hunterkiwi01 's stable of steeds 7 Quote
felixx Posted April 27 Author Posted April 27 So I think I got all the airleaks sorted, she idles and runs better Lots of rust on the chrome.. Hit it with a brass wire wheel and crc.. Came up lovely 4 Quote
felixx Posted April 27 Author Posted April 27 She is coming along well I will try and get the black plate on her.. 8 Quote
felixx Posted April 28 Author Posted April 28 So once she is warm, she runs well but takes 100s of kicks when cold. She backfires but wont start until she does Thinking: Valves clearances Timing Points and / Condensor All of which I dont know how to do, but I do have youtube. When its warm it goes well but will eventually just die if left to idle for more than 2 min What order do you suggest attacking my list? Is there anything more to add? Quote
mo999 Posted April 30 Posted April 30 On 28/04/2026 at 16:34, felixx said: So once she is warm, she runs well but takes 100s of kicks when cold. She backfires but wont start until she does Thinking: Valves clearances Timing Points and / Condensor All of which I dont know how to do, but I do have youtube. When its warm it goes well but will eventually just die if left to idle for more than 2 min What order do you suggest attacking my list? Is there anything more to add? Certainly clean / check the points (and points gap) is the choke flap closing properly? It will definitely need choke to start when cold - does it start better with a shot of easy start? 1 Quote
Lord Gruntfuttock Posted April 30 Posted April 30 When it's cold check for spark, and fuel. If it has both, a compression test might indicate valve issues. Could be as simple as finding the choke position it needs to fire. If the plug is wet it could be flooding. My CTs the same, takes a million kicks when cold. Pull plug and dry it and it normally gets going. 1 Quote
Tumeke Posted April 30 Posted April 30 Charge your battery? The old C50s need voltage to make them excited. They're better when up and running. 2 Quote
felixx Posted May 1 Author Posted May 1 21 hours ago, Lord Gruntfuttock said: When it's cold check for spark, and fuel. If it has both, a compression test might indicate valve issues. Could be as simple as finding the choke position it needs to fire. If the plug is wet it could be flooding. My CTs the same, takes a million kicks when cold. Pull plug and dry it and it normally gets going. Hmmm I will be checking valves as it starts easy when warm, there is a little smoke, but this could be a rings issue.. borrowing a compression tester tomorrow morning, hoping its not rings just for the sheer buggery involved 21 hours ago, mo999 said: Certainly clean / check the points (and points gap) is the choke flap closing properly? It will definitely need choke to start when cold - does it start better with a shot of easy start? Choke flap appears to be closing correctly.. off to google points check technique tonight.. Start ya bastard appears to do not a lot 3 hours ago, Tumeke said: Charge your battery? The old C50s need voltage to make them excited. They're better when up and running. It has no battery, however a new one is waiting for pickup tonight, along with tyres and brakes Quote
Tumeke Posted May 1 Posted May 1 i would encourage a CDI upgrade on this bad boy if you feel like a challenge. Lifan parts should bolt on from memory. Quote
felixx Posted May 1 Author Posted May 1 5 minutes ago, Tumeke said: i would encourage a CDI upgrade on this bad boy if you feel like a challenge. Lifan parts should bolt on from memory. Maybe next points change, for now I just want to get the thing going Quote
Tumeke Posted May 1 Posted May 1 1 minute ago, felixx said: Maybe next points change, for now I just want to get the thing going just be aware the points that steppybits on TM and some others sell are pretty average reproduction units. A multimeter and a 6v bulb are really handy for timing them per the honda workshop manual. 1 Quote
felixx Posted May 1 Author Posted May 1 1 minute ago, Tumeke said: just be aware the points that steppybits on TM and some others sell are pretty average reproduction units. A multimeter and a 6v bulb are really handy for timing them per the honda workshop manual. So I guess a stator and 'starting loom' off a Lifan will be whats needed with a CDI, Guess that is converting the Cub to 12v as well I have a couply dead 90cc lifans hiding somewhere, could scrounge em off them? Quote
