Hey OS, I've got a job on the Levin that requires a bit of welding finesse, so wanting to query the collective brain of OS before I charge ahead and screw something up.
I decided to solve my rear tyre rub issues properly by cutting out the offending sheetmetal, which will be replaced by 1.6mm trailer guard material. I've cut the inner guard approx 25-30mm up from the lip, which will butt into the inner of the trailer guard. Car is fully painted/finished so need to be careful to avoid massively screwing up the exterior. Inside the car it's not in a noticeable area so I'm confident I can tidy it up.
Was thinking something like this;
A few questions I have before I embark
1. Can either Tig or Mig it - which process produces less heat? Mig? Any tips/tricks? Planning on a few stitches in the sensitive areas, then panel bond/seam sealer on both sides.
2. Also after experience/opinions on heat sink options to draw heat away from the paint;
  • Welders Putty/heat blocker?
  • Wet cotton pillowcase full of wet sand??
  • Wet cloth/towels?
  • Any others?
Thanks in advance for your help!
Not steel, but when I used to braise copper pipe where it went into a building, i'd wrap a wet rag around the pipe which stopped any heat getting past it. I can't comment on how the electrons will react to a wet rag, but I feel like if you had one tucked in against the exterior panel and in that wheel arch lip on the right, it would help a lot. I've only ever done MIG on my cars and a single spot weld in one area, then moving to another area to put one does keep the heat down a lot. Just my thoughts anyway, i'm sure others have done very similar jobs to yours. Only mentioning it as the wet rag wrapped around the pipe was a very simple solution but worked perfectly.
Pretty cool stuff. Example is with copper, and eventually the heat capacity of the gel will be exceeded, but it looks to be pretty effective.
Id think its probably far enough from the outer skin yould probably be fine there.
A good fitment for your patch will be key! big gaps = more weld = more heat
Just take it slow (tack, wait, tack cool, tack..)  so the wider area doesnt heat up, and make sure any paint you care about is protected, not just direct weld but also from splatter and wire hedgehogs incl from the inside - accidentally zapping the outer skin from the inside would grind my gears!
I dunno about leaving a damp rag in there while welding or having water touching the actual weld, but have it on hand for cooling the metal around the area in case you forget rule 1 (take it slow!), but imo a air line would be safter/better.  some copper (or aluminium) backing for belts and braces esp if your fitment isnt good.
My personal preference would be to mig it with .6 wire and co2 for the gas as i reckon you can get better penetration at a lower amperage (just my opinion on gas selectionhete). Run a longer post flow for extra cooling if it's adjustable on your machine, if not a second click of the trigger will give you another dose of gas
I think the access sucks enough for tig to be annoying, even though I hardly ever use my mig these days..And agree with others around  tack wait method.
If you want some extra insurance you could get someone with a purge cup to backpurge the HAZ with argon as that will cool the back side of the weld very quickly. This is a bit unconventional with mig and maybe overkill but hey.
Cover up the inside of the outer skin to stop any splatter finding it's way into the seam.
TL:DR
I reckon inert gas is the best cooling method.
I have a beryllium copper dolly to use when doing patches jam behind the weld heat gets pulled through in to copper and steel doesn't stick to it, can also hammer on to it without stretching the metal to buggery.
Its carcinogenic as fuck apparently (so you gotta hold your breath)........ but it does work well at pulling heat out.
  • Haha 1
This job actually worked out OK. I used a air blower to cool the patches after a few stitch welds, and just moved around. No melted paint even though it was only 30-40mm inside the guard. The stretched metal and not being able to clean paint off the backside was the worst part (and the PITA welding position). Many many burns were experienced. Not lining up to do this job again in a hurry.
if I was to do it again - 0.6 wire would of helped, and a smaller welder. I used Geoffy's 250a and it worked, but only right at the bottom end of its range. Lets just say I filled a lot of holes...
