SOHC Posted January 30 Posted January 30 1 hour ago, kws said: Rover V8s run low pressure, but high flow, for instance. 10-15psi idle, 35psi @ 2000rpm Yep and if you mess with trying to fix that it will probably blow up 1 Quote
Lord Gruntfuttock Posted January 31 Posted January 31 Ironhead's the same. High flow low press, lucky to get 5 psi... Quote
SOHC Posted January 31 Posted January 31 2 hours ago, Lord Gruntfuttock said: Ironhead's the same. High flow low press, lucky to get 5 psi... They have a roller bottom end so only need a drop every now and then, just the cams need a constant flow 1 Quote
Muncie Posted March 29 Author Posted March 29 Should update this, Turbo is on still makes 55psi cold and sits just above 40psi hot has a couple of tanks of gas through it now. I have a ticky lifter occasionally which is pissing me off I think I may need to drive it more and give it some beans to loosen things up. Quote
felixx Posted June 17 Posted June 17 On 24/01/2026 at 20:04, morkster said: This might be Ling It is not the same without him, I hope he is living his best life somewhere 2 Quote
