RXFORD Posted January 10 Posted January 10 I'm needing a thermo switch that I can fit into an Ali radiator hose adaptor/joiner. I can weld in a threaded boss to suit no problem so thread doesn't matter, but being that its not earthing on head/rad, I need recommendations on a good switch that I'm guessing will be 2 wire. Doesn't need to be a fancy adjustable one or dual temp, just looking to make the current setup, which is a manual dash switch, more user freindly. Cheers Quote
Raizer Posted January 10 Posted January 10 https://www.repco.co.nz/parts-service/electrical-parts-vehicle-management/switches/oex-thermal-sensing-fan-switch-cfs49/p/A1197357 Close at 100 degrees Celsius Open at 95 degrees Celsius Thread M22 x 1.5 Factory in a bunch of small Holdens, pick a part for a plug. Quote
RXFORD Posted January 10 Author Posted January 10 Thanks, sorry I should have been a bit more informative. I was hoping to here what other have used without failure as there seems to be a big price difference between some listed through supercheap/repco etc, and Davies Craig / Spal switches that are $100 upwards. Don't want to buy some cheap thing and have it fail, but it others have used them successfully then I'l take the punt. Quote
Raizer Posted January 10 Posted January 10 Have personally used a Fuelmiser switch (oex is just the supplier) in the past, as far as I know it's still working fine now but I don't own the car anymore. I only linked that specific one as it's down from $120. Quote
sheepers Posted January 10 Posted January 10 @RXFORD, the Tridon ones are pretty good. ive only ever had one fail because it was as least 20 years old and it didnt fail, it just changed resistance so the fan came on to soon. their range is pretty good to so you can find something to suit without to much drama. Quote
vk327 Posted January 11 Posted January 11 Tridon tfs133 m16x1.5 is one of my goto 90 on 85 off and 2 wires so crimp to what ever suits Or tfs106 95 on 90 off m14x1.5 2 blade terminals 2 1 Quote
0fnsiv Posted January 24 Posted January 24 https://www.trademe.co.nz/a/marketplace/building-renovation/heating-cooling/other/listing/5740012719 this style of thermostat is an easy fix……cheap, you can sikaflex the sensor to the top tank, or even insulation tape it to the top hose….. I normally weld a tube into the hot tank of the radiator….. it’s adjustable and if you want it can be used as a digital temp gauge…. Quote
hohocc Posted January 24 Posted January 24 I fitted an electric fan to a Suzuki Vitara a couple of years ago. Used the fan switch from a Honda, can't recall what sort but it seemed every Honda at pick a part had the same one fitted. Worked best in the outflow from the radiator, inflow had it turning the fan on a bit too often. Used a fan controller from a Nissan Pulsar I think, and fan/shroud (cut down a bit) from a Ford Mondeo (single fan). Anyway it's still working fine, and any Honda part is probably the most reliable part of the car... Quote
