What size/how many killer wasps is your lathe motor?
I assume your shed has three phase?
Might know a guy who knows a guy who might have a spare vsd and who could programme it
  • Replies 66
i think the motor is about 7kw, the VSD is 7.5kw.
currently the problem is that the VSD got repaired (at massive expense) and i reinstalled it and the motor will only turn a few very slow revolutions before the VSD gives an overload error. (we have tried changing every variable in the program to no gain)
the error code says over current or short to ground, the way the spindle rotates (kind of stop start, as if one winding is not working)  points towards a possible issue with the motor.
we tested the motor windings resistance and they were all the same but we didn't have have an insulation tester. thats next on the list - confirm that the motor does not have a short then go from there.
man i miss my lathe. so many things i need to make........
  • Sad 1
Waaa that's a pain in the dick.
You are welcome to borrow my insulation tester or I could swing by at some stage and give your motor a fondle
3 minutes ago, rusty360 said:
Thanks will give it a bash.
It's a miracle worker. Apparently, it's quite easy to make it at home with basic ingredients and get the same/better results.
Recipe here. I'm a recent covert to the evaporust now trying to be a cheap ass. This guy's recipe is better and can be reused a lot longer
  • Thanks 2
Stock.
But lower,  few mechanical upgrades to update parts that you can't get anymore.
All new suspension and bushes.
Wheels too. dunno what wheels,  but wheels.
It'll be a fucking ace car for someone,  just not me.
