  • Replies 89
My apologies if I missed it, but what differential are you running?
That looks like a nissan one?
You're not running an R200 are you?  For the power levels/weight of the car, an R180 would be plenty big enough. The bigger diff will have greater driveline losses too.
4wd primera/Avinir had a LSD r180 rear diff.
Yea im pretty sure mines a locked r180 but im not a big Nissan dude so not 100%.
20e powered A31/C33/r32 ran the r180 with those 2x3 flanges.
The primera/avinir had a 1 piece inner CV iirc. (Not flanged)
If you get a viscous LSD you'll need the matching inputs, as one side has the longer secondary spline to engage the viscous cartridge
  • 4 months later...
Whoa, custom metal bellhousing is cool as.
Good progress.
How is the other car going?
Coming to OS drags to school some nerds in their Nissane Notes?
(Highly personalized attack towards @xsspeed )
  • Haha 5
Good progress.
The other cars are going backwards in progress. Once the Platz runs it’s full steam ahead on the itb car till it’s Finished hopefully for summer.
Did you end up removing any metal from the firewall? Always excited when I see updates from you.
Hi im Nick.
Im addicted to taking photos of platz.
Maybe somebody needs to call you out for drag day
  • Confused 1
Hi im Nick.
Nope no metal on the fire wall was removed. Only the tunnel will have to be made a bit bigger. I also made sure there is plenty of room behind the engine so it’s not a pain to work on. Engine weighs so little it’s not too much of an issue having it so far forward. (Nothings welded or finished just a mock up in the photo below)att.kXHWMG0XnLMZuSqQjmzy494LPvdWm1XpgKlNFMLGQts.thumb.jpeg.2f75508a0b6756f3cc83fcf15c67615a.jpeg
  • Like 9
On 23/09/2026 at 12:33, Marino Fischer said:
Since my last update I’ve done quite afew things. I’ve fully mounted the engine and box, made a custom drive shaft, shortend axles and adapted an exhaust manifold to work. Currently im working on a custom intake manifold to work with the rwd layout. Once that is done and my cv boots arrive it’ll be ready for a test drive. att.qwAE65_fULLaUseywk6j4oAu6sJwrU_TaXBtVoHRF4M.jpeg.7c45ce06b87376264ca3819f3b7fd55b.jpegatt.OMtR8BHmJdm-3J2-V7Q-SrLgHE_prTW4Wp__aho01Gs.thumb.jpeg.720a1bc4313b523753ded6f1ca27168f.jpeg
The inlet and exhaust have quite pleasant symmetry. Its also begging for a Turbo.
4 hours ago, Muncie said:
The inlet and exhaust have quite pleasant symmetry. It’s also begging for a Turbo.
I’ve almost got everything to go turbo minus waist gate and intercooler/piping. But I need to test the work I’ve done so far na and also learn how to drive a rwd without ending up in too many ditches😆
