Of course the clutch pedal assembly had been bodged by a previous owner. Why wouldn't it have been?
I noticed it a while ago, whilst putting the missing clevis back in the brake pedal, that the clutch pedal was a bit... weird. First, it was missing the correct C clip, instead someone had just hung an incorrectly sized circlip on the shaft, which promptly fell off.
It should have a clip like this
Second, the pedal had been welded together. From what I have gathered, looking at diagrams, the clutch pedal is from a first-generation mid-late 80s Alto. None of the newer Altos use this style pedal.
I don't love bodges, particularly on things like pedals.
So, from the same HA11S at Pick A Part I got the coolant pipe from, I also sourced a complete manual pedal box. I had seen on some Japanese sites that the H Chassis pedal box will fit and work, it just needs some processing. What, I wasn't sure of yet.
My original plan, since I didn't want to remove the pedal box from the car, was to remove just the pedal and swap them over. The one in the car was easy, since the clip was missing. I just unhooked the clutch cable, popped the spring off and slid the pedal off
The pedal was way more butchered than I expected
Compared to the replacement pedal I removed
Unfortunately, the H chassis (donor) pedal doesn't fit the (butchered) C chassis (my car) pedal box. The pivot for the pedal is longer on the C chassis and doesn't use bushes. It also has different limiters for the pedal travel, using the arm at the top of the C chassis pedal to stop the pedal, whilst the newer H chassis has limiters further down the pedal, with nice little pads.
This does mean that I had to remove the pedal box anyway. It's held in place by two vertical bolts and four nuts holding the brake booster in. The column center bearing is also attached to the pedal box with two studs/nuts.
Original C Chassis box on the left (with new pedal attached) and newer H Chassis box on the right
It's kind of weird, it almost looks like the clutch part of another pedal box has been welded onto this pedal box...
The brake pedal switch needed to be swapped between the two, as one switch was 2 pin and the other 4 pin. This is just held in with a lock nut and then the switch is screwed into the pedal box
The switch also sets the brake pedal height at rest
Getting the pedal box in and out is zero fun. I hate working under dashes, particularly around the column, which just flopped around and got in the way
After a few tries of getting the new pedal box into place, finding the insulator pad fouling it, cutting some of that away to clear the box, I then found out what "Processing" the box needs...
H chassis on the left, C chassis on the right. The vertical bolt spacing of the newer pedal box is different.
After some measuring, I grabbed the Dremel and cut out some metal. In hindsight, it would be neater looking and maybe a bit stronger if I had drilled an oversized hole where it needed to be cut
Regardless, I checked it lined up and fit, quickly coated the bare metal in some paint, and fit the pedal box. I used a couple of large washers on the upper bolts to spread the load.
Other than those two bolts, it all bolts in place good, everything hooks up fine, and it seems to operate as it should.
  • Like 9
One of the last things I needed to do before I could look at starting the engine was to refresh the axles and refit them.
I wanted to clean and regrease the CV joints and replace the boots. The boots were looking a bit sad, and the joints themselves seemed really floppy.
Using a small flat-blade screwdriver, I popped the tabs on the metal boot retaining bands and removed them
The outer joints appeared to have been serviced at some point, as the grease was different to the inner joint, and the boots were newer and less perished (although both had a few little pinholes in them). The grease on these ends was quite hard and clumpy.
On the other end, the inner joints had really old, perished boots, and the grease was horrible, smelly, slimy stuff. Nothing like cracking open a boot and releasing the smell of rancid fish.
According to the manual, only the inner joints can be disassembled. The outer joints are not serviceable. I could probably pop the axle out if I hammered on the joint, but without a spare, it wasn't worth the risk.
With the boot undone, the joint cup just pops out, and the spider slides out and is free.
I wiped as much grease off the joint and out of the cup as I could, and sealed it in the rubbish bin
To remove the boots, I needed to remove the spider. This is held onto the shaft with a retaining clip. Annoyingly its one of the ones that just has tapered ends, not holes for circlip pliers. I managed to pop it off (and not lose it) with circlip pliers and a small flat-blade. It didn't once become a "Ping-Fuckit", I'm so proud.
The spider just slides off the splines
With both boots removed, I thoroughly cleaned out the outer CV joint, using brake cleaner, rags and a screwdriver to carefully scoop the grease out
Once cleaned, I dried the joint and then packed it with new Redline CV grease and slipped a new boot on. The cheap Aliexpress CV band tool did the job well. You wind the excess band onto the tool using the handle on the left, and once it's tight, bend the tool up and over to crease the band (so it won't just undo) and the handle on the right cuts the band. Remove the tool and hammer over the little retaining tabs. Done.
Rinse and repeat, and you have an axle with nice new boots and new grease. A quick wire bush job gets rid of all the external grease, too.
This is the state of the older-looking inner boots. Very hard and perished. Not cracked through yet, though
I ended up using almost a whole tub of CV grease between the two axles, after packing all the joints and boots
I was sure to clean out the needle bearings on the spiders and run new grease into them
That left me with a pair of nice, clean and fresh axles
With new hub nuts and washers
Fitting them wasn't too bad. I ended up removing the bolts from the struts and letting the hub hang down. Pop the inner joint into the gearbox, wrangle the outer into the hub and bolt the suspension back together
I took a couple of minutes to replace the outer tie rod ends, too, as the old ones were a bit floppy
I rattled the hub nuts up for now, but I will need to properly torque them to the required 150-260NM (it's a really broad range in the manual) once I can have a helper hold the hub still with the brakes.
Now that the axles were in place and the gearbox didn't have gaping holes in the sides, I pumped some nice new GL4 fluid in and capped it off, ready to move onto the next job.
  • Like 9
