nels Posted May 14 Author Posted May 14 Had to load up the boot with weights and doors to try get it down. Its roughly a couple inches off at the moment. 5 Quote
nels Posted May 17 Author Posted May 17 Pretty happy with this..just need more weight in the car..I’m about 2 inches off 4 Quote
nels Posted July 1 Author Posted July 1 Started working on the tilt front. First job was to weld some tabs to the bonnet so I could bolt the fenders to it. main thing was to get the gaps right and flush the fenders to the bonnet. Came out all good Next job is to work in some bracing and tie it all in to where I’m going to pivot the whole thing. 3 Quote
Popular Post nels Posted July 5 Author Popular Post Posted July 5 Bracing for the top end is all done ready to bolt in place and should tighten it all up. On to the pivot points. 17 1 Quote
nels Posted July 21 Author Posted July 21 Started work on the lower bracket for the pivot points. This piece will follow the curve of the front sheet metal and be mounted where the front pan and fenders bolt together. using a 25 x50 x 2mm bar with drilled and filled holes. 5 Quote
nels Posted August 16 Author Posted August 16 Got the front bar all sorted and pivot points done. 5 2 Quote
nels Posted August 16 Author Posted August 16 I need to sort the front end out now before I go any further on the tilt front as the front struts will impede the internal cross bars I need to put in. Looking for an Lj torana front suspension if anyone knows of one. 1 Quote
nels Posted September 2 Author Posted September 2 Front ends out and trimmed off the radiator support. I will start on cleaning up the firewall 4 Quote
Popular Post nels Posted September 4 Author Popular Post Posted September 4 All the holes I need cleaned up are all done. 10 Quote
