  • Replies 84
So I had planned to go to the Brooklands event on Saturday but with 3hrs sleep and so much work completed I was still a distributor and coolant away from completing reassembly at the time I was ment to leave, so mission failed.
and the backup car plan was also broken so I got to stay home and rest.
anyway I got it together and couldn’t start as carb was overfilling (previous owner had taken them to a shop for a rebuild with receipts) with the bowl removed the gasket was cracked and silicone was everywhere but float and needle looked ok
now do I glue it back together to run it in, or rebuild them properly or do I splurge and just get the Webber kit or a pair of HS6 to keep the std look
  • Like 8
Found the alternator fault was now a wiring issue. The wire that was not showing 12v Should be directly wired to the starter battery connection and the other wire next to it should be exactly the same but bigger has 12v
so pulled off the insulation and found lots of rerouting that I now have to fix
the plug for alternator has been replaced with one with different colour wires and the wire I’m having trouble with is wired to a different circuit and the original is still there going nowhere but has 12v
while I’m there I should also sort out the mess they also made of the ballast resistor delete
i just want to run in the engine
