MRT1TRD Posted April 26 Author Posted April 26 Keen eyes will spot my amateur error here, I blame it from being from northland and anxiety of things rusting immediately I had to strip the welded areas for inspection, but that is signed off now but not so tidy looking had one small fire to the roof lining when tacking rear bars but not bad damage 9 Quote
Popular Post MRT1TRD Posted May 3 Author Popular Post Posted May 3 A new day some 2nd hand pipes , sadly the new pipes I ordered to Finnish off the main restriction of the exhaust did not show, so I had to make do with some leftovers I had are enough to make it work for now 10 Quote
MRT1TRD Posted May 7 Author Posted May 7 With the exhaust fitted I started it and it was leaking from the original slip joint which is what I wanted to get rid of with the new parts, What I ordered eventually showed up so mad late nights Tuesday and Wednesday to make it how I wanted and test drove it to work, sounds great, quieter at idle, less bark, but a more deeper sound, sounds more smooth like a modern EFI engine than a lazy design old English engine I highly recommend adrenaline R mufflers , I have two spare if anyone wants to buy 9 Quote
MRT1TRD Posted May 8 Author Posted May 8 I can’t fit as much stuff inside with the swing set installed 5 Quote
Popular Post MRT1TRD Posted May 9 Author Popular Post Posted May 9 A perfect day out in Timaru , new front tyres and wheels made it faster on corners, tho had a spin at the end of the straight using 3rd to slow down but it popped out but I had not kept the revs up when I rein gaged it, didn’t stall so just select first and give a thumbs up to the marshal and keep going 15 Quote
MRT1TRD Posted May 11 Author Posted May 11 The wheels are not quite right preferably +20 not 28 and it would be the rear that might rub on the inside guess I have to make a swaybar and panhard to prevent that. The other two wheels are red centres so I need to paint, and was considering black with gold around the holes like ’75 anniversary wheels but with the front fitted they look good in black 7 Quote
MRT1TRD Posted May 16 Author Posted May 16 Customisation of cars can be a real pain, trying to install kill switch with remote pull has been an experience with trying to look discreet the switch works but hopefully no one needs to pull the cable tho it should work once but I am now worried I have to remove dash to make it right, then I might just replace dash wiring while there, change to oil pressure light not gauge , find more rust, when I just want to have fun. tach now goes to 7k with key on and starter motor is getting worse “click” 7 Quote
Popular Post MRT1TRD Posted May 18 Author Popular Post Posted May 18 So first proper racing event done for the club day at ruapuna I started at 2.09 and got down to a 2.04 by the end of the day. Had to be polite to others when they are lapping 1.50-1.40 eg: way faster and 3rd race was handicapped so I was first then last by lap 3 but not counting the 5 cars that didn’t last the day it’s definitely a high speed track, I achieved the factory top speed of 105mph right when I needed to slow for corner, still not confident with tyres and brakes for a full send into it. Pic of rain light, I made it plug into rego lights and bolt onto plate holder with plate removed 11 Quote
MRT1TRD Posted July 30 Author Posted July 30 Another nice winter day out, it was -4deg in the morning was a little slippery in practice but was a nice sunny day, I have not done anything to car apart from removing tacho to find a burnt circuit board inside, have to find a replacement so I know how much I’m pushing the poor thing. Got down to a 2.02min lap & more consistently that I didn’t get lapped in the last race so got to run 6 laps instead of 5 pic showing two cars that were damaged before lunch so didn’t make the day 9 Quote
Popular Post MRT1TRD Posted August 10 Author Popular Post Posted August 10 I was thinking about doing an event on the 8th of August in Timaru but decided to inspect the engine. I did it at the right time as I would have needed a tow home if I ran it again, it’s pretty good considering, no sign of crank or bore damage. But good bye moneys for rebuilding now. It is already 0.5mm oversized so 1822cc and crank is -0.25 so it’s had a bit of work before. Only other issues is one inlet valve looks to have vice grip damage which deleted the valve seal. I will get rotating parts balanced and a hone and maybe some porting 12 Quote
Popular Post MRT1TRD Posted August 13 Author Popular Post Posted August 13 Happy 1yr anniversary 11 Quote
MRT1TRD Posted August 18 Author Posted August 18 The engine shop has gone through my bits, the block is 5thou worn so max hone + ring size but recommend os pistons which I would have done if the head was not cracked (did notice some colour last plug check during last event). Anyway does anyone know of a good big valve head or a modified one fs no zetec pic of the tide line on my ultrasonic 6 Quote
MRT1TRD Posted August 26 Author Posted August 26 Thanks for peoples help in locating a head turns out the engine shop had one on the shelf ready to bolt on . I had phoned around the local mg repair shops and one just had a spare one refreshed that I could buy. since I spent lots of money on getting some head I was wondering how could I afford a new tachometer, but the algorithm found what I wanted.. a new from nz store 8k tach with shift light for $28 +$9 overnight shipping, I couldn’t not get it for the price all installed and switching on just there’s no pulse from coil for some reason 5 Quote
MRT1TRD Posted August 30 Author Posted August 30 This alternator bearing has been noisy since I brought the car, first time I’ve seen this design, have to desolder the brush connection to remove it , hopefully I did it correctly and it works again 6 Quote
MRT1TRD Posted August 31 Author Posted August 31 Spent way too much time making this hideous sump baffle, I think I will buy a proper alloy baffle sump once I save up some more money, but hopefully It improves the longevity of my bearings till then 8 Quote
Popular Post MRT1TRD Posted September 7 Author Popular Post Posted September 7 Found out why the engine tends to slow when clutch is depressed 13 Quote
