  • Replies 84
I don’t recommend the spax kit. I now understand why it was “new only test fitted”
shocks knock on upwards movement (I spent hours diagnosing, it is in the shock)
the upper mount plate placed the shock just touching the floor (thick under seal but still) once the rubber bush sagged a little it will be hard up reshaping the rear passengers ass
then the lower mount was just a nut and bolt which if it got slightly loose it would work the spring base a new one
I replaced the lower mount with a correct pair of mounts I had lying around
driving it seemed much the same possibly a little harder than the good cond lever action shocks,
the noise would be annoying if I did lots of city driving, but engine noise quickly overwhelmed it
So for its 6mth anniversary it received a new distributor and valve on top of booster
the valve caused a too lean issue with the carbs (still is abit lean) but have been readjusted since I got rid of my brake whistle
the distributor was 1/5th of the price of the car but you get that, hopefully is reliable. So far I have it tuned to 3deg at idle and 38 at 5k+ and it seems more happy to rev to 5k than before
will need a better cam and some head lightening to get some more rpm out of it, is there any recommendations for camshafts? I have heard mixed reviews about Kelford
I have been struggling to get this fitted for months, glad I went with a regular size seat not the next size up as it’s a tight fit, now I’m not looking forward to have to take it in a out many times to fit the next lot of things
Pick a part find overflow tank, drilled a hole to fit the grommet for the lower mount a clamp for the top, and it fits just right, nope I had to remove 5mm off each fan blade but hopefully it is more efficient with the bottle acting as a cowl (temp is fine)
But with radiator now full to the top it now leaks from the rad cap slightly ( change one thing require another car life)
Best thing to do two days before a big trip is to pull the front end apart to replace pads, rotors, seals, pistons, bearings. I still want to upgrade the front brakes but they needed love for now, might go faster if the pads aren’t dragging
  • Like 8
Made it to Timaru, I have two spare weekend tickets for southern classic for someone who pretends to be my crew, no issues for the first day though went to SCA for a new rad cap and fuel cap and windshield cleaner . I am officially the slowest car out there
  • Like 8
If you dig a hole eventually you’ll find water, if you remove enough parts off a classic car you’ll find rust.
The floors has had some repairs that I knew about and they were nicely painted rustkill grey on top and under seal black below. But after removing most of the interior I found that I needed to remove some of the factory sound deadening on the passenger side and all on the driver side (some of the passenger side was blistering above the exhaust for some reason)
Passenger side attacked and treated and also inside the C pillars but I’m still working on drivers side which will need some metal repairs
  • Like 8
Removed the seat and more sound deadening to reveal some more rust to work on, there is some more hideous areas in the front that I’m trying to ignore that have been patched from below but left the rust on top but the rust kill did hinder further growth, I did consider importing a new floor pan but maybe at A later date
