  • Replies 73
Been shopping like a lottery winner over the last few weeks, tho nothing expensive yet (keep backing out of purchases from England (does anyone know how to get a Bluetooth electronic distributor that’s not $800+))
so plenty of things to keep this off the road and not driving while I mechanically restore this with a few mods
brake upgrades I am not sure what route I wish to take, the Holden route or get some big rotors that fit to the original hubs, I do have some callipers from a Alfa mito at pick-a which are a little big for the 22mm Holden disks they were 28mm disks (how thick can I go)
anyone got smaller callipers to swap?
Put the suspension and original brakes back together for now and took it to work, was following the road bumps badly so might have to give it a quick alignment before going home
With a bit more driving I can confirm it drives better on actual winding roads, feels more confident to turn in. Just lacking the power to match it
Towards the end of a weekend trip I went over a depression and there was a loud bang, turns out the bump stop didn’t like being closer to the diff and jumped out of the car
  • Haha 3
I found that strut buddy bump stops fit perfectly over the mounting B plug
Mechanics have lots of these lying around in parts hoards
Pic of the original one that stayed around for reference
If you reading this you can put some input on what the future holds for this on the discussion thread- Thanks
I missed a pic of the idler gears thrust bearing wear - inserted
I spent last night researching wiring, wow so much money could be spent on just a rewire. So many cool options to empty bank account, PDMs galore, solid state battery disconnect with CAN communication etc etc
The fitting of a wing back chair in this has proved a bit of a challenge to get it where I want it and my supervisor is not helpful
I have moved the rails further back now but would like to space the front higher as I have maxed out the seat angle on the cheep seat brackets and still tending to lean back
also does anyone know a engineer who could redrill and spline a boss kit that I have or know where to buy a quality boss kit to suit only one I have seen the casting looked poorly
After a little holiday I got home and spent a bit of time with the wiring and fuel pump
Pump is a NZ made one and other company’s that sell it recommended a 1.5L/M not just 1 for a MGB which makes sense as I took it on the motorway in the morning so constant 3800rpm could overwork the pump trying to keep up.
I have emailed the company and will see if they come back with any information to support this
I have tested some of the wiring and think I don’t need to replace the wiring just clean up the poor connections and get rid of the poor bypass wiring used to compensate the poor connections
So more of a overreaction on how bad this was I will continue with this driveline and maybe consider a conversion in the future
And my goal will be to enter into the https://classicmotorracingclub.nz/regularity-trial/
in February
So with a bit of time this morning I have removed some weight, cleaned up some connections, replaced one, and set up for when I find or buy some solder
last fault to fix is the parking lights not always working when headlights are on
