Nearly bled the brakes, by which I mean I did three out of four corners but one nipple was seized & rounded off so it's going to be dualies off so I can get at it properly.
I'm also going to need some bigger spanners.
Not entirely convinced It's not actually the master cylinder letting by but here's hoping a big load of air comes out the last wheel cylinder
Also had a look at the tomfoolery that is the tipper controls. It's a period bed, piston & pump but the linkages are all homemade & the levers are totally in the wrong place. They're s'posed to be tight against the seat base.
They are currently where your foot needs to be for starting, driving, braking etc. Not ideal. and the hole in the floor is pure butchery.
I'm going to move them. Maybe to the bin & just bolt the bed down, or go the whole hog & change it for a wooden cargo bed which is probably what it came with. I'll check serial numbers though & if it was an earlier steel one I'll just get rid of the tipper gubbins.
  • Like 8
