ThePog Posted July 21, 2025 Posted July 21, 2025 My sister in at the beach and the water pumps in her new bus have randomly stopped working. I have run her through the obvious things like fuses but she isn't as technical as requires. Could anyone near rock down there with a multimeter and have a squizz? With a relay or two and some wire it should be possible to bypass the wiring fuckery and hook up directly to the power supply which is in the same side compartment. All 12v. In return she will feed you something epic, give you nice beer and tell you stories of exactly how much of a cunt I am. Ping me for deets - Ta. 1 Quote
ThePog Posted July 22, 2025 Author Posted July 22, 2025 Belay that, she got all technical and squeezed the relay terminal connections and it works now, fuck the patriarchy! 3 1 4 Quote
