gibbon Posted July 8 Posted July 8 going to EFI on the triumph. next up is the fuel system I see there are arrangements which cap the return on the fuel rail, and the fuel pressure regulator is located way back at the outlet of the fuel pump and does everything from there. seems like a simple and easy way to setup a "return" system without meters of hard pipe. but conspicuously the OEM doesn't do it, so what's the story? Quote
Nominal Posted July 8 Posted July 8 Returnless is actually pretty common in OEM these days. Some link I found from 2014. e.g. AutoSpeed - Modifying Returnless Fuel Systems, Part 1 1 Quote
tortron Posted July 8 Posted July 8 corvette combined FPR and filter was all the rage for engine swaps 5-10years ago. dont need a regualtor on the rail, or a return 3 Quote
gibbon Posted July 8 Author Posted July 8 3 minutes ago, tortron said: corvette combined FPR and filter was all the rage for engine swaps 5-10years ago. dont need a regualtor on the rail, or a return yeah I think that's the thingy I'm looking at, reasonably priced too. Are there any downsides for a non bleeding edge application? Quote
bigfoot Posted July 9 Posted July 9 I have seen it done with a normal aftermarket reg with a tee going to the rail between the pump and the reg, it worked for the burnout the car did. Don't know if they kept it as a permanent solution Quote
kws Posted July 11 Posted July 11 Certain BMW E46 fuel filters have a reg built into them and return from the filter https://skunkworks.co.nz/products/e46-m54-fuel-filter Quote
gibbon Posted July 12 Author Posted July 12 looks like it's a somewhat common thing now, I make no apologies for being stuck in 1993. but yes looks like I'll go with a nonreturn system to save the extra plumbing Quote
GARDRB Posted July 13 Posted July 13 https://www.sq-engineering.com/wp-content/uploads/2022/12/Info-Beams-fuel-system-Phil-Bradshore.pdf Quote
Tumeke Posted July 13 Posted July 13 Not sure if you have seen this, and it's a bit old tech now, but might have some useful stuff still. https://sites.google.com/a/mintylamb.co.uk/triumph2000efi/ 1 Quote
