gibbon Posted June 11, 2025 Author Posted June 11, 2025 10 hours ago, dmulally said: They then got spun up on some fancy massive machine to balance them and get a report for LVV and job jobbed. Cost me maybe $300 all up that's a good point too, I'll ask CDC if their off-the-shelf axles come balanced. The LLVTA lists "axle modifications" as requiring a cert but reading into it, it looks like they might be talking about live rear ends more than anything Quote
dmulally Posted June 11, 2025 Posted June 11, 2025 1 hour ago, gibbon said: that's a good point too, I'll ask CDC if their off-the-shelf axles come balanced. The LLVTA lists "axle modifications" as requiring a cert but reading into it, it looks like they might be talking about live rear ends more than anything My Imp goes to LVV this month some time and the engineer mentioned he needed to look more into what the cert process is for half shafts. If you go down that path tag or PM me and I'll let you know what I needed. I just got the paperwork from the engineering shop just in case. I'm not sure if I'll need to get them crack tested or not. Quote
gibbon Posted June 11, 2025 Author Posted June 11, 2025 hey @cletus just to save me asking the same question in the certs thread, what do you think about this, do aftermarket half shafts require a cert? Mine are "professionally manufactured" (according to the UK seller, who don't supply any kind of engineering declarations with the parts), and dmulally's are locally built Quote
cletus Posted June 12, 2025 Posted June 12, 2025 If you're talking about an aftermarket replacement bolt in half shaft and everything else is stock, and it's a shaft only ie not a jag where the shaft is also a "suspension arm" , probably not If it's to fit some other diff like a datsun etc it would need a cert for that anyway so would be covered at the same time 2 Quote
gibbon Posted July 4, 2025 Author Posted July 4, 2025 On 12/06/2025 at 08:27, dmulally said: My Imp goes to LVV this month some time and the engineer mentioned he needed to look more into what the cert process is for half shafts. If you go down that path tag or PM me and I'll let you know what I needed. I just got the paperwork from the engineering shop just in case. I'm not sure if I'll need to get them crack tested or not. how did you get on? 1 Quote
dmulally Posted July 4, 2025 Posted July 4, 2025 1 hour ago, gibbon said: how did you get on? Still waiting for the call off the bench. He just had major dental surgery so I dont want to push him. He is 20 mins away so wont be a drama when the time comes. 1 Quote
ahebron Posted July 4, 2025 Posted July 4, 2025 What about looking at the relatively new trend of the side by side off road buggys. They have independent rear ends and the diffs dont look that big plus they might have lockers built in. Even a front diff could be an option, rotational direction dependant. Adrian Quote
gibbon Posted July 4, 2025 Author Posted July 4, 2025 I actually ended up buying a drop-in LSD unit which replaces the weakest part of the diff, so kept what I have and hopefully that will be enough. bought an off-the shelf CV axle conversion kit as well, the whole cost being.... oh shit probably more than an R200 and conversion kit, whoops 1 2 Quote
VitesseEFI Posted July 7, 2025 Posted July 7, 2025 On 04/07/2025 at 08:40, gibbon said: more than an R200 and conversion kit, whoops There’s a kit that fits an R200 in a small chassis Triumph?! 🤔 Quote
gibbon Posted July 8, 2025 Author Posted July 8, 2025 11 hours ago, VitesseEFI said: There’s a kit that fits an R200 in a small chassis Triumph?! 🤔 I typed out a big long answer to this while thinking "surely this guy already knows about the datsun diff mod".. then realised I meant to say R160! 1 Quote
VitesseEFI Posted July 8, 2025 Posted July 8, 2025 2 hours ago, gibbon said: then realised I meant to say R160! Uh huh….. And there was I getting all excited 🙂 1 Quote
ahebron Posted July 31, 2025 Posted July 31, 2025 BMW diff and CV conversion https://www.ebay.co.uk/itm/146740966706?_skw=Triumph+Vitesse&itmmeta=01K1E01KWT6DNDT6GXRFWNM36N&hash=item222a717532:g:RHUAAeSwY0Zoihlo&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1f3NdFYZXB1cRC9rKUjGLyeiT1BEGLbkjpmu9eXMd%2F%2BikEtJm6Kr4by%2Fzs44OJcEP5JzS9z85BTJCmXbe4%2FpL5tKnf3zvq4n4LOjlE0zPqNHQx3guPXefFT39dNRZP809aLuO1OWrGRuplprZ78%2BbsnfYR0QB0RjGD7q03tg5AzOWmnpbZUwHFedDy0sevhyKeLIq9EvkEzG4c%2FxuyO7dlefVim5mFMCgWufrV4qpWSgjV00LHmYZHmTSTlM8D103JDOndtWhQu2qaH3DXpP06eAc9Ys%2FsdzrPApxt01wkr%2Fg%3D%3D|tkp%3ABk9SR-K-hsCLZg Quote
VitesseEFI Posted July 31, 2025 Posted July 31, 2025 Oh yeah…. Just been looking at this. Very strong (and expensive) diff, paired up with what looks remarkably like my Rover Metro CV driveshafts - which are much less strong. Not convinced about the vertical link location methods either, especially the top arm. Quote
