Rear end finally out. Some rivets took 2 minutes and others took 45 minutes. Filthy and disgusting work which you can see by the floor under the chassis. Whilst in the air I did some wheel spinning and it's a 4.10:1 ratio diff. Should be ok with 31" tyres for around 2000rpm at 60mph. No idea if the transfer case changes ratios or not.
After work today I'll start on the front end. A little bit more tricky as I have to sort out the steering box. Speaking of I have to make some decisions on that sooner rather than later. The box it has is flogged and an exchange rebuild is around $650 plus shipping to and from the US.
I have options though. I can get a bracket to put on a power steering unit. Then I'd need the BMW pump and no idea if that would fit in my bay or even work. I could also just get mine rebuilt and if I'm feeling frisky enough, put a prius electric power steering column under the dash. A common mod for classic chev owners in the states. I would have to run any of that by the cert man however and I'm worried he'll hear the word Prius and slap me with a white glove.
Unless anybody has any better ideas? Answers on a postcard here. I haven't ever played with 4wd stuff before so I have no idea what works and being LHD it puts me at a disadvantage in God's country.
  • Like 9
Right then. Mind made up and sticking with 2wd. It should save me 6-12 months and $6-12k. Looks like Ill need an air locker and a big fuck off winch however.
Spoke with the engineer again and it's pretty simple and will modify the old V8 brackets.
Messenger_creation_AD3F3EA3-6AF2-4417-B43C-B1B0D85C974B.thumb.jpeg.fcadff1b363ce1644cb3d703234e9850.jpeg
  • Like 9
