How do you change your name on here?
Because I actually haven't done any drifting for years nor own rbs anymore and its making no sense. I'm worried I'm miss leading the people and it's damaging my clout
  • Haha 2
Cool wagon. I used to have a POS 1984 slant front (I guess you'd call it that vs twin headlight).
Great to see one being kept on the road. Pretty underappreciated but a solid platform I reckon.
I've had a few of those,
Will dig out some old pics, also got another wagon I built with @82Mirage and @OSM Garage for fun activities like burnouts and dirt drags that's twin headlight aswell
4g63 sohc block from an L200 I dragged out of a paddock
Starion pistons, second hand re used rings and bearings.
Fwd 8v 4g63 sohc head
Balance shaft delete
Fwd intake cut shut for rwd
Starion exhaust manifold
Td05 turbo
38mm external gate 13psi
510cc Evo injector
Nzefi ECU I think?
Original build melted a piston because boost solenoid played up and let it do over 20psi this is second build.
Currently I need to upgrade the clutch it was grabbing gears but is slipping now
On 06/04/2025 at 00:58, RXFORD said:
I have a rear window with seal and stainless trim if you would like a spare.
Which stainless trim are we talking about?
Td05 turbo
510cc Evo injector
Nzefi ECU I think?
Sounds mental. I remember when SOHC 4g63ts could be had for under a hundy out of the Loot/T+E. Good times
Oh I'm good cheers though. I would like to find a number plate trim. I had one on a wagon years ago but they're hard to find
Didnt the skid wags have one? I have one to suit FL model, but PFL are different (wider)
